C3 Capet Question
Old Aug 1, 2015 | 09:25 AM
jfg15's Avatar
jfg15
Default C3 Capet Question
Need to replace carpet on a 70 Convertible.
1.) Coupe and convertible use the same carpet?
2.) Is their a preferred vendor for quality and ease of installation (minimal cutting to fit)?
Thanks JFG15
Old Aug 1, 2015 | 11:24 AM
AkrHack's Avatar
AkrHack
Thanks JFG15
The carpet set for a convertible is different than what would fit a coupe. Also, the carpet set for a 4-speed car is different than the set that would fit a car with an automatic transmission.
Old Aug 1, 2015 | 02:06 PM
Rotonda's Avatar
Rotonda
Thanks JFG15
ACC brand carpet worked for me. Suggest you contact Willcox to order.
Good service and 15% to 20 % off on order.
Old Aug 1, 2015 | 02:10 PM
tpfarm's Avatar
tpfarm
Willcox Corvette has sales frequently for carpet. It's ACC carpet and is good quality. I replaced my '73 convertible carpet last winter with their carpet and was satisfied with the quality and fit except for the wheel wells , they were a bear to fit. Do a search on this forum for carpet and learn as much as possible from people that have done it.
It takes patience but you can do it yourself . Good luck.
Old Aug 1, 2015 | 05:18 PM
Tommy79's Avatar
Tommy79
ACC carpet for me was a poor fit that required a lot of customizing to get it to half way fit. I would suggest looking at a higher quality carpet than ACC.
Old Aug 1, 2015 | 08:26 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
In my humble opinion, there isn't a higher quality carpet being made
I'm surprised you had any issue with the 1978-1982 carpets from ACC, we installed a set four months ago and it was a great fit for us
The only thing I complain to ACC about on the 78-82 cars is that too much trimming is required... and when you install the side boards on the shift console you must make sure to pull the carpet up about 1/16" so that it tucks under the shifter console and parking brake cover better than the GM carpet did.
I own a very low mile 1978 and did published some documentation on the factory flaws in that car, one of the issues when the cars were new was the fit of the rear carpet and the most annoying is how horrible the factory kick panels and the center console carpet looked when installed.
In regards to the earlier cars, about a year ago we started working with ACC to make needed corrections in the carpet sets. Every year was corrected from 1968-1977. On the 1968-1972 cars we now have pictures on our facebook page and on the Willcox Repair and Installation Help Site that will make installing the rear wheel humps way easier.
Here is what I'm talking about on the shift console... Please ignore the sheep wool covers, they were on the seats when I got the car.
Here is the factory kick panel carpet as installed (1978)
Old Aug 1, 2015 | 09:37 PM
Roozstr's Avatar
Roozstr
I installed an ACC carpet kit in my 73 coup 4 spd last January. Fit was really good. No Complaints.
Old Aug 1, 2015 | 09:42 PM
Tommy79's Avatar
Tommy79
Default Just not so "custom"
My expectations was that I would not have to "custom" cut a ton of places to get it to some what fit. As cutting does not fix the areas that the carpet should have been molded, you get areas in corners that overlap and pucker up. Not a great look.
Did not like the looks of the console carpet sides and cut 2 more backings and put matching leather on them. Trashed the carpet.
The carpet for the front is molded to fix. No real issues. No reason the back also could not be done the same way.
Advertising the carpet as "custom fix" is just not true for the rear carpet. The installer should be prepared to spend a lot of time to get a so-so looking install.
If the descriptions of the carpet provided the real details, I would have looked elsewhere and/or paid a professional to install better quality carpet.
To C3 Capet Question
