Bubba makes an airconditioner
Old Aug 2, 2015 | 04:16 PM
PRNDL's Avatar
PRNDL
Default Bubba makes an airconditioner
I am making the long hot drive to Carlisle in a few weeks in my 68 bigblock with no A/C. Good news is the car runs fine in hot weather without overheating. Bad news is without A/C it is freaking hot in there when it's above 90 degrees!!! So with a little help from my friends on Youtube I put together this DIY air conditioner. Styrofoam cooler, $2.50 at Walmart, 12v clip-on fan $14.99 at Autozone (removed the clip and added an electrical receptical for $2.99). Bought a couple of pvc plumbing vents for $3 at Lowes. I think I can make my own ice, probably by freezing plastic milk cartons. I will let you know how it works!
Old Aug 2, 2015 | 04:31 PM
ddawson's Avatar
ddawson
So the fan forces the air in then two vents that point at you?
Not a bad idea for a long drive.
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I like it!
Old Aug 2, 2015 | 05:14 PM
kanvasman's Avatar
kanvasman
I don't think the NCRS people will approve this. ON the other hand, I already know how to upgrade it if it works. YETI. I love when people think outside the box and thanks for giving me a good laugh today. Let us know how it goes.
Old Aug 2, 2015 | 05:15 PM
GRipp 73's Avatar
GRipp 73
What do you tell the passenger? Maybe cut a second hole for their feet? That would keep them cool right?
I like the setup. Any test runs yet?
Old Aug 2, 2015 | 06:09 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Put me down for two!
EDIT! Flash of light! ALSO.......fill the wiper tray with ice cubes/Open kick panel vents..........
ASTRO VENTILATION WITH A/C!
Old Aug 2, 2015 | 06:21 PM
toobroketoretire's Avatar
toobroketoretire
Genuine redneck engineering.......................
Old Aug 2, 2015 | 07:50 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
I can't wait to see this!!!!
Old Aug 2, 2015 | 08:21 PM
pawpaws toy's Avatar
pawpaws toy
Cool!!!
Old Aug 2, 2015 | 08:24 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Beautiful addition to a Vette.
Old Aug 2, 2015 | 08:47 PM
Technite73's Avatar
Technite73
Why not use dry ice. No water to worry about and it lasts a long time.
Old Aug 2, 2015 | 09:45 PM
68/70Vette's Avatar
68/70Vette
If it's a coupe, have a look at Vintage Air..Also..Classic Air.. You can buy the air conditioning/heating console piece and the above air cons and no one will know from the interior appearance you've an aftermarket air con. I think there's a problem with Vintage Air/Classical air and 68 Convertibles..a body brace is in the way under the passenger's dash board.
Old Aug 2, 2015 | 09:58 PM
The13Bats's Avatar
The13Bats
Swamp coolers or the cooling by evaporation work great in dry climates but here in fl it just makes a swamp more humid.....
Old Aug 3, 2015 | 09:31 AM
gbvette62's Avatar
gbvette62
Depending on how strong the fan is, when the ice starts to melt, it may start to blow water, or at least water vapor, out of the "vents".
What you have there is basically the same thing as an auto racing cool suit. The difference is that a cool suit pumped water through the cooler, and through tubes in a vest, worn under a driving suit. Early cool suits caused a lot of problems for drivers, when the ice melted and the resulting water quickly heated, pumping 100 + degree through the vest! Changes to the systems, as well as the use of high capacity medical grade coolers, have lessened the likely hood of this happening.
If it doesn't work, stop by and see me. I'll be on spaces A 19-23, and I'll have plenty of cold beer and water with me!
Good luck with your bubba air!
Old Aug 3, 2015 | 10:15 AM
PRNDL's Avatar
PRNDL
Probably wouldn't be an issue in my well ventilated convertible, even with windows and soft top up, but I don't think it's a good idea to increase carbon dioxide levels at the expense of oxygen in the car cabin.
However, I am considering mixing in some rubbing alcohol (methanol) with the water that I am freezing in bottles. My kitchen freezer goes down to -1 or so degrees and water freezes at 32, so it seems a shame to waste that cooling power. I think I will use plastic bottles frozen in my freezer to avoid having to deal with a cooler full of water when the ice melts. I am going to test it later this week and if it doesn't help I won't bother using it on my drive north because it does take a lot of space. And when I get to Carlisle I can offer help to anyone whose car has overheated. Here, have a bottle of water spiked with methanol!
Installing Vintage Air is a bit more of a commitment than this, dont ya think?
Old Aug 3, 2015 | 10:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by kanvasman
...I don't think the NCRS people will approve this...
Owner Installed Option.
Old Aug 3, 2015 | 04:28 PM
John 65's Avatar
John 65
When I work outside in these crazy temps I sometimes wear a Texas cool vest.
A vest with inner pockets that carry frozen packets that wraps around your upper body. They recharge in ice water in about 1/2 an hour. Not exactly ac, but it sure does help keep the body temps down. Good luck with your project.
To Bubba makes an airconditioner
Old Aug 4, 2015 | 08:20 PM
toobroketoretire
The best way to stay cool when working in heat is to drink lots of cold water because it cools the inside of you where cool is needed most.
Old Aug 4, 2015 | 09:08 PM
spjrr's Avatar
spjrr
What I have done a few times in my 69 vert is keep a couple cold bottles of water topped by a couple of the same frozen in a small soft side cooler sitting on the parking brake console all the way back between the seats. The soft cooler doesn't insulate that well so you can put your arm on it and that helps to cool the rest of you sort of. It does help and you have the option of drinking the cold water as well... Humid summers here in Minnesota can be a biach with humidity in the 90+ relative range.
Mark Smith
Old Aug 4, 2015 | 09:59 PM
centralcalvette's Avatar
centralcalvette
Love it. Made my day.
