Help with 81 power locks!
Old Aug 4, 2015 | 11:32 AM
Jantonb's Avatar
Jantonb
Default Help with 81 power locks!
OK Gurus,
The power locks were not working at all and I was also having issues with window regulators, so I've decided to rebuilt the doors completely…windows, motor, regulator, panels, arm rests…the works. I purchased 2 new lock switches, 2 lock motors and 2 new pigtails.
Installed all new lock components, pigtails, switches and motors. Connected the battery back up and immediately blew a fuse. So…yeah….there is a short….but where? I blew 2 fuses trying to find it. I did discover that with the switches not attached to the pigtails, no short happens. Help me track down the short or what's causing the short. Pigtail wires are butted to corresponding colors with the exception of the driver's side. Pink(original) to light blue (replacement) and Purple (original) to black (replacement)
Ideas?
Old Aug 4, 2015 | 12:16 PM
MelWff's Avatar
MelWff
did you check the wire harness that passes through the conduit from the door to the body?
Old Aug 4, 2015 | 01:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: check the relays for locks and windows.
Old Aug 4, 2015 | 05:14 PM
Jantonb's Avatar
Jantonb
MelWff,
I have not…will do that soon.
Old Aug 4, 2015 | 05:15 PM
Jantonb's Avatar
Jantonb
FWIW,
Where are the relays for locks and doors located? Does the same relay control both locks and windows? Window motors work fine.
Old Aug 24, 2015 | 09:43 PM
Jantonb's Avatar
Jantonb
Default Problem Solved!!!
The problem was 2 brand new bad switches!!!! China POS!!!! Got 2 new switches from auto (does not say "lock") and presto! All now working!! Thanks to all the gurus for the leads! You helped a great deal!!!!
To Help with 81 power locks!
