Never Night Performance Headlights for C3
Old Aug 17, 2015 | 09:52 PM
spedaleden's Avatar
spedaleden
Default Never Night Performance Headlights for C3
I am thinking about purchasing this from speed direct, has anyone installed this?
http://www.speeddirect.com/index.php...mance-lighting
Old Aug 17, 2015 | 10:07 PM
The13Bats's Avatar
The13Bats
While I am into old school I do dig the newer non sealed beams with the changable bulbs, I even like halos,
I can't speak for the plug and play wiring kit but the bulb part is very cheap on ebay, and I suppect that all these type bulbs come in as imports so
Old Aug 17, 2015 | 10:47 PM
Richard454's Avatar
Richard454
I can't tell by the pic- but the Hella replaceable buib lights I used- did take some modding to fit the high beam. They look similar as far as the size at the back of the bulb- so you might have to open up the hole a bit-I'd ask.
I am waiting for replaceable LED bulbs to swap out my Halogens.
I made my own harness- theirs does look nice!!!
DSCN5145 by Richard Hayes, on Flickr
Visegripped a piece of metal - so the hole saw had a pilot-
DSCN5140 by Richard Hayes, on Flickr
just a little bit needed to be remove-
DSCN5144 by Richard Hayes, on Flickr
DSCN5143 by Richard Hayes, on Flickr
****************EDIT*******************
Yep-Website says you have to modify housing....
Old Aug 18, 2015 | 06:33 AM
dembo's Avatar
dembo
Very happy with it and a big improvement. Besides enlarging the buckets all fits well
Nick
Old Aug 18, 2015 | 06:55 AM
midigike's Avatar
midigike
I think this is a smart mod to do, personally I want to do this and I think it is worth the money, and can save your life. I was coming home last week from a car show about 9 pm and easily "out running" my headlights.
Thanks for posting.
Old Aug 18, 2015 | 07:03 AM
dgr72vette's Avatar
dgr72vette
If you scan E-bay they do have some there that require no modification to the buckets...also come with a small ceramic harness extension. I have them and love the extra light output. (only did low-beams)
Old Aug 18, 2015 | 08:43 AM
Richard454's Avatar
Richard454
Be carefull of some of the stuff on eBay-
Here's two ceramic extensions that LOOK identical in the pics-
However the one on the right plainly has bigger-better contacts-
DSCN4931 by Richard Hayes, on Flickr
And the wire- small gauge aluminum versus larger gauge copper-
DSCN4927 by Richard Hayes, on Flickr
Old Aug 18, 2015 | 09:17 AM
toobroketoretire's Avatar
toobroketoretire
I would think its tin-plated copper and not aluminum. Its very common for wires to be tin plated to resist corrosion.
Old Aug 18, 2015 | 11:25 AM
Richard454's Avatar
Richard454
When was the last time you bought something on eBay? It's totally "Caveat emptor."
As far as the "ceramic harness" on the left- It(wire) was not magnetic-and when if you tried to use a heat gun for heat shrink- the wire would melt before the heat shrink would reduce. Total crap!!!
Then there is other stuff out there that is "CCA"- or copper coated aluminum wire- doesn't conduct near as well as copper and you bend it a couple times and it breaks.
To Never Night Performance Headlights for C3
