Knocking!
Old Aug 19, 2015 | 05:47 PM
jtl1567's Avatar
jtl1567
Default Knocking!
My engine just recently started knocking. i am going to change the oil this weekend. and see if its the spark plugs. Any help would be great!
Thanks a ton
Old Aug 19, 2015 | 05:48 PM
jvp's Avatar
jvp
"Ask Tadge" Producer
Thanks a ton
What year car?
Old Aug 19, 2015 | 05:56 PM
jtl1567's Avatar
jtl1567
sorry for not including that vital info haha. its 1977
Old Aug 19, 2015 | 06:40 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Remove the belts and start it......if the noise goes away....it is the main bearings.
If not...it is either piston related, rod related or valvetrain.
Pull valve covers and check for broken rocker.
Pull oil pan to verify rods of course.
Good luck to you.....never a good scene when something is knocking.
Jebby
Old Aug 19, 2015 | 09:00 PM
jtl1567's Avatar
jtl1567
What am i Verifying on the rods? and what main bearings?
you will have to forgive my ignorance im new to corvette and
working on cars in general but want to learn.
Old Aug 19, 2015 | 09:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You or somebody needs to wiggle each rod on its journal for slop. If there is....that is the noise.
On the mains....belt tension on a loose main journal can amplify noise....
If you determine the bearings are bad.....then you need to remove it and repair or replace.....
I hope that clears it up a bit.
Jebby
Old Aug 19, 2015 | 09:28 PM
jtl1567's Avatar
jtl1567
Jebby
alright. ill start by taking the belt off. the main bearing are the ones on the drive shaft am i correct?
Old Aug 19, 2015 | 09:38 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No....fan belts. You should do a little research on the issue online. Not beefing critical but would seem your knowledge of engines is limited.
One of the best pieces of print known to Chevy-dom:
http://www.amazon.com/How-Rebuild-Your-Small-Block-Chevy/dp/1557880298
Get this and read it.....my father bought me a copy when I was 11-12 years old
It will tell you pretty much what you need to know so you can tackle your problem armed with knowledge.
Jebby
Old Aug 19, 2015 | 10:32 PM
garym52's Avatar
garym52
are you sure you're not hearing valve ping? could be something as simple as low octane gasoline.
Old Aug 20, 2015 | 07:32 AM
COOLTED's Avatar
COOLTED
Loose torque converter bolts can make a knocking noise. that's way easier to fix than bearings, I would check that first.
Old Aug 20, 2015 | 07:49 AM
diehrd's Avatar
diehrd
Cut oil filter open look for metal .. Check flex plate a crack will cause a knocking more often then loose bolts.
Can you post a clip of it so we can here the knocking ?
Old Aug 20, 2015 | 08:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You don't mention checking the oil level.
Old Aug 20, 2015 | 05:04 PM
69monzacpe's Avatar
69monzacpe
You could use an old trick, get a piece of garden hose or similar (heater hose) and with the engine running hold one end to your ear and place the other on the valve covers moving front to back. If one of the rockers is knocking, you should be able to get close to it without pulling the covers. If you hear the knock, move to the intake runner on the side with the knock and using the hose set it on each intake runner. If one is louder, check the rockers on that piston. It also could be a stuck lifter, or fuel pump push rod. Does it knock once per engine revolution or more?
Old Aug 20, 2015 | 07:30 PM
toobroketoretire's Avatar
toobroketoretire
I keep a 6 foot length of 1/2" low pressure hydraulic hose for siphoning fuel and for listening for the source of noises. When it comes to finding the source of a noise NOTHING beats a hose held up to your ear and I've been using one for 50 years.
Old Aug 20, 2015 | 09:52 PM
lowbuck72's Avatar
lowbuck72
I've been using a large screwdriver with the handle end as the earpiece. That being said, rod knocks are rare on small block Chevy's and main bearing knocks are even rarer. Valve train noises are much more common. Worn main bearings are a very deep and thudding type sound, rod knocks are crisper and get louder when you take your foot off the gas, no load. Piston slap, (worn rod small ends and wrist pins) are tinnier. But a more likely suspect is a bad lifter, valve, guide, rocker, or bent pushrod. Just my $.02 cents.
Old Aug 21, 2015 | 12:32 AM
Sunstroked's Avatar
Sunstroked
I have to laugh, I recall carpooling with a kid from A&P school some 30 odd yrs ago. We heard a knocking sound, hmm whats that, then a major ugly loud bang. That was the rod coming out the side of the block.
Old Aug 21, 2015 | 12:35 PM
REELAV8R's Avatar
REELAV8R
Main bearings are more of a deep rumbling noise.
Rod bearings are a knock knock consistent with the RPM.
Valve train is more of a sharp clack clack or clickity clack noise.
Any of those sound familiar?
To Knocking!
Old Aug 22, 2015 | 09:19 AM
derekderek's Avatar
derekderek
do not attempt this alone. everybody's first attempt at self-taught crank work ends in noisy disaster. you may get away with replacing rods and mains, but these aren't cars we drive around at low throttle. they won't last. you need an engine. or a rebuild.
Old Aug 22, 2015 | 12:18 PM
jtl1567's Avatar
jtl1567
ok sorry it took me a while to respond. the oil level is fine just recently replaced it. the old oil was smooth didnt have any grit too it. like i said just had the transmission worked on so i will check for loose bolts. i did pull off spark wires and the noise did not go away. also the noise is most loud near the rear of the engine.
Old Aug 22, 2015 | 12:24 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
As posted above by previous member....check the torque converter bolts!
Jebby
