small block 350 valve covers
Old Aug 20, 2015 | 01:24 PM
BillyGags's Avatar
BillyGags
Default small block 350 valve covers
Hey there everybody. I plan on painting my valve covers Chevy orange this weekend, along with new valve cover gaskets. I was just wondering if there are any torque specs on the valve covers. Because what I'm thinking is you want to "crush" your gaskets juuuust the right amount. Thanks for you input #weekendwarrior
Old Aug 20, 2015 | 02:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm not aware of a sequence, but all you do is snug them down.
Old Aug 20, 2015 | 02:28 PM
Aggitated Monkey's Avatar
Aggitated Monkey
If we are talking about stamp steel 4 bolt perimiter I have my own thought. I like to snug down the lower aft then lower fwd then the uppers. On cast just go around equally. I also like the FelPro gaskets with the insert that's prevents over squeeze of the gasket
Old Aug 20, 2015 | 08:45 PM
Paul L's Avatar
Paul L
Good advice and nice product. Money well spent.
Old Aug 20, 2015 | 08:47 PM
thb72's Avatar
thb72
the 72 service manual lists it at 45 inch pounds
Old Aug 20, 2015 | 08:56 PM
Iceaxe's Avatar
Iceaxe
Fel pro #1628 gaskets are worth every penny. They stopped all my leaks and they are reusable.
Old Aug 20, 2015 | 09:26 PM
BillyGags's Avatar
BillyGags
Sweet I bought an entire FEL-PRO kit
Old Aug 20, 2015 | 09:27 PM
BillyGags's Avatar
BillyGags
thanks man I'll go with that. I have a 76 but a 350 is a 350...
Old Aug 20, 2015 | 10:22 PM
jr73's Avatar
jr73
those rubber gaskets are insane I will never buy cork again
Old Aug 20, 2015 | 11:09 PM
Aggitated Monkey
Another thought. If you have sheet metal covers make sure they are not warped in any way. Set them on the heads after clean and without the gasket to make sure they set flat.
Old Aug 21, 2015 | 07:57 PM
Paul L's Avatar
Paul L
Anyone ever figured out why GM used a rounded edge to seat the gasket on the stock head metal surface? Logic would say it should be machined flat.
Old Aug 22, 2015 | 07:46 AM
Easy Mike's Avatar
Easy Mike
Yep. Not much more than snug.
To small block 350 valve covers
