Reverse Shift Prob
Old Aug 27, 2015 | 11:17 PM
Vettesic's Avatar
Vettesic
Default Reverse Shift Prob
Having problem shifting manual into reverse in my stock 71. Hard to get shifter over and into the reverse gear. The shifter is actually moving the console cover over to the left. Can I adjust to shift easier?
Old Aug 27, 2015 | 11:30 PM
TimAT's Avatar
TimAT
Something is loose. The lever should not get that far to the left. If it's the factory installed shifter, the frame of the shifter could be bent. I'd check for anything loose, then check all of the adjustments per the manual. Bushings are most likely worn too. Good news is rebuild parts are available.
Old Aug 29, 2015 | 12:10 AM
Vettesic's Avatar
Vettesic
Thanks for info
To Reverse Shift Prob
