69 electrical issue
Old Aug 28, 2015 | 11:36 AM
ScottE's Avatar
ScottE
Default 69 electrical issue
On my 69 the Amp/Battery gauge is jumping and the lights go brighter as it jumps around. The alternator was replaced @ 10 years ago and it doesn't have that many miles on it. The battery always has a tricle charge connected when its sitting in the garage.
Can someone give me some direction where to start, or possible things to look at for?
Old Aug 28, 2015 | 11:39 AM
jnb5101's Avatar
jnb5101
I would check for a bad connection at the battery terminals, ground wires and the horn relay. Do more than look at them, remove the wires, clean the connectors and reassemble. It sounds like a loose wire.
Old Aug 28, 2015 | 12:28 PM
derekderek's Avatar
derekderek
replace the voltage regulator. it is separate from the alt up till 72 or 73 or so.
Old Aug 28, 2015 | 01:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...replace the voltage regulator. it is separate from the alt up till 72 or 73 or so...
Nope. It's built in beginning with the 69s. 68s are the only C3s with a voltage regulator on the fender skirt.
Old Aug 28, 2015 | 07:23 PM
jnb5101's Avatar
jnb5101
It may be the regulator, but because I'm cheap I like to start with the free stuff.
Old Aug 28, 2015 | 10:20 PM
TimAT's Avatar
TimAT
I like free stuff too. The dash has a ground on the left side A-pillar- it's 100% beotch to get to- behind the dash pad about 2-3 inches above the hood release. And it's in a perfect place to get wet. And not make good contact.
Check every ground you can find.
Old Aug 29, 2015 | 07:19 AM
derekderek's Avatar
derekderek
or just run a new one from dash to block. even a quickie out the window and under the hood to see if any change...
Old Aug 29, 2015 | 12:47 PM
ScottE's Avatar
ScottE
Thanks everyone for the suggestions. I thought it might be a grounding problem.
To 69 electrical issue
