Putco Plasma LED bulbs
Old Aug 28, 2015 | 05:32 PM
couperdecar's Avatar
couperdecar
Default Putco Plasma LED bulbs
I've tried regular LED 1157 bulbs in the tail lights. Not overly impressed. Read an article about the new Putco Plasma LED 1157 bulbs. Anyone tried them? They're quite a bit and I'd like someones opinion before I lay out my $
http://www.autoanything.com/lights/p...asma-led-bulbs
Old Aug 30, 2015 | 06:55 PM
couperdecar
I can get 6 red ones from West Coast Classic Cougar for $70.
Cheapest I can find. Anyone try these?
http://www2.cougarpartscatalog.com/s...d-Mustang.html
Old Aug 31, 2015 | 02:53 PM
couperdecar
Talking with a buddy - he had a set ! I bought 'em and WOW are they bright. Major major difference. Didn't have to get and aftermarket flasher. Plug and play. REALLY GOOD upgrade !!!
Old Aug 31, 2015 | 03:53 PM
Rotonda's Avatar
Rotonda
The best bulb you can use in place of 1157 is a 3496. You can get them from your local Honda dealer. Part number is 34906-SL0-A01. It draws the same amount of current as 1157, but is much more efficient. It produces 43 candlepower on the bright (brake or turn) filament, and 3.5 candlepower on the dim (tail or parking) filament. It is filled with krypton gas (Inside of bulb won't blacken with use) and has a nickel-plated base that is much more corrosion resistant than the plain brass base of an 1157 - feels like quality when replacing and less likely to stick in the socket. For comparison, the 1157 produces 32 and 3 candlepower, so the 3496 bulb is 33% brighter when braking or flashing turn signals - times when you really need the brightness.
THE BEST PART IS THAT YOU DON'T HAVE TO MESS AROUND WITH REPLACING YOUR EXISTING FLASHER (NO GOING INTO THE DASH) OR FINDING A PLACE TO MOUNT RESISTORS LIKE YOU DO WITH LED's.
Old Jun 6, 2016 | 05:09 PM
BillbUrruss's Avatar
BillbUrruss
Default LED tail light
Just bought the same ones today because his YouTube was soooo convincing. His are called Plasma LED's and they look much brighter than the regular LED's. Another little project, I can't wait!!!!
Old Jun 6, 2016 | 09:31 PM
mrvette's Avatar
mrvette
Some time ago I bought some LED RED 1157's for the rear of my vette, yes they are BRIGHT, but the way they made them, they will not fit the sockets.....I was going to mod the sockets and housings, but honestly it's too little gain for so much work....
Old Jun 7, 2016 | 12:04 AM
Barry's70LT1's Avatar
Barry's70LT1
I've been using 2357 bulbs for a few years. (40 Candle Power)
They are readily available from any automotive store.
The Plasma LED 1157 bulbs sound very interesting.
Old Jun 11, 2016 | 09:44 AM
BillbUrruss
Default LED's
You know when I read this I thought how hard could it be, 1157 bulb out, 1157 LED in. Well the LED's were not exactly the same. I couldn't get them in far enough to twist and lock. They pushed in but I couldn't turn them in, even with a pair of padded players. I measured everything as well as I could and they seemed to be identical. This is BS, I'll make them fit!!!
They needed to go in just a tiny bit further so I filed the bottom 2 soldered contact completed flat and there was still lead covering the contact points. They turned right in!!! I removed them and liberally smeared dielectric grease on all the contact points and now I feel like a genius!!! They're at least two or three times brighter. These are called Plasma LED's and I bought them from West Coast Classic Cruisers after seeing their YouTube.
Old Jun 12, 2016 | 01:09 PM
Swift_C3's Avatar
Swift_C3
got a link to that Youtube video?
Old Jun 12, 2016 | 02:34 PM
BillbUrruss
I just Googled "West Coast Classic Cougar" and one of the sites was the Youtube
To Putco Plasma LED bulbs
