68 gauge bezel
Old Aug 28, 2015 | 11:35 PM
dugsgms74's Avatar
dugsgms74
Default 68 gauge bezel
Has anyone bought a repro 68 only(smooth finish) center gauges bezel that can speak to its quality/fit. Mine is broken in 3 places and since I took it apart today to replace the fiber optic cables was thinking about buying one but don't want to spend the $240.00 if its doesn't fit right. Thanks in advance.
Old Aug 29, 2015 | 01:38 AM
JC68's Avatar
JC68
The overall quality/fit is actually pretty good, on par with the original, the problem is the mounting lugs for the wiper switch/Corvette name panel to screw into is cast in the wrong location. It is about 1/4 inch to far back. The originals have no gap. The mounting screws won't line up with the cast holes unless you do some rework.
I've attached a picture to highlight the problem area.
John
Old Aug 29, 2015 | 03:46 AM
dugsgms74's Avatar
dugsgms74
John,
Thanks for the heads up. Is there enough "meat" on the new bezel to drill new holes?
Doug
Old Aug 29, 2015 | 01:55 PM
JC68's Avatar
JC68
John,
Doug
I haven't done the rework to mine yet, but it looks like it should be OK. The screws they use in this location are plenty long to cover the gap, the problem I see is the new holes you will need to drill will be near the edge of the existing hole in the wrong position. It could make it difficult to drill.
John
To 68 gauge bezel
