Head light door adjustment
Wow .. I had this issue with the driver's side and resolved it thanks to this forum by the adjustment of the 3 bolts holding the springed linkage.
On the passenger side,the door will not open all of the way. So I loosen the three bolts holding the springed linkage and allowed the bracket to slide forward. Low and behold the door opens fine .... but then it doesn't close all of the way. It almost looks as though the actuator doesn't have enough stroke. I've gone through several cycles of this. Is there any other adjustment I can pursue?
Received 1,469 Likes
Cruise-In II Veteran
You may have to give the clevis on the actuator rod a couple of turns.
