I need 3 Grill dimensions...Please.
Measurement "A/A" is from the outside edge of the flat area on driver's side over to the center hole in the grill bracket.
Measurement "B/B" is from the outside edge of the flat area on driver's side to the outside edge of the flat area on the passenger's side (a straight line across).
Measurement "C/C" is from the outside edge of the flat area on driver's side to the corner of the flat area shown.
The measurement you want are very difficult to make on an assembled car with any accuracy. Are any of the original brackets or mounting holes in place? The AIM gives dimensions to location the holes for the lower outside bracket off it's mounting pad. Do you have that pad?
The grill fit is pretty tight at the end with the chrome surround pieces. You want to get the end gaps even. The top outside bracket is mounted to a hole in the headlight door frame and is not easily moved. I think you might be best off by test fitting everything is place and drilling the bracket mounting holes based on that.
John
Do you have 68 brackets or 69? The 69 are sturdier. Also the two new 68 only lower inner ones that I purchased, did NOT fit the angle of the grill at all!. Lou.
John
I should receive the chrome surround pieces this week/I already have the 3-piece grills, the 4 grill brackets, and the chrome bumper.
Your explanation and pics are just what I need to make the modifications (I hated to see the '68 car sit/butchered-up....so I bought it knowing I would have to spend $$$$ just to resto-mod it)
So.....thanks for taking the time....the fixed headlight assembly will be my starting point......you gave me the info that I needed without the need for numbers/measurements.
This should be easier now!
I bought the '69 brackets "by mistake"......good thing......LOL!
I'll make the brackets/anything fit at this point...LOL (again).....I need to "re-shape the outside edges of the opening to fit the shape of the '68 L & R grills.....
As you can see from the pic....the P.O. had the round turn signals screwed into the '76 grills.
Maybe later on I'll buy the correct clip....but for now "close is close enough"....I'm still trying to make the car drivable/legal.
and you too, derekderek................LOL!
I'll try to get some pics of the downtown area.
Thanks!
https://www.corvetteforum.com/forums...e-project.html
Doug
