1981 headlights
Old Sep 9, 2015 | 10:39 AM
rolltidechris's Avatar
rolltidechris
Cruising
Default 1981 headlights
First of all I would like to introduce myself. My name is Chris and I am from Mobile,Al. I have recently purchased a 1981 and 1 headlight will not close. The guy I bought it from stated there was a override switch for this but he wasn't sure where it was, I am trying to find it. Anyone have a clue where this is located or have any other advice? Thanks in advance.
Old Sep 9, 2015 | 01:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The headlight override is beneath the steering column. Did you get an owner's manual with your 81?
Old Sep 9, 2015 | 01:49 PM
rolltidechris
Cruising
No sir, I didn't get the owners manual.
Old Sep 10, 2015 | 09:54 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
Looks like this.
Old Sep 10, 2015 | 10:13 PM
rolltidechris
Cruising
Originally Posted by 64roadster
Looks like this.
Thanks, I found it but the light still will not come down. I will take it in the morning to a corvette shop and get them to help me. I appreciate all the help.
Old Sep 10, 2015 | 10:14 PM
gbvette62's Avatar
gbvette62
Unless the lamps were opened using the vacuum override switch, it shouldn't close open lamps.
When you pull the override **** down, the headlamp doors will open. Pushing the **** back up, closes the doors. If the **** wasn't pulled down to open the doors, then it won't close headlight doors that are opened.
The headlight doors normally open and close, when the headlights are turned on and off. The purpose of the override was to allow the owner to open the lamps, with out turning on the headlights. This was so that you could clean the headlights, or leave them open in snowy or icy weather.
If the doors won't close with the override, then you have a problem with a vacuum actuator, relay valve or a vacuum hose.
Old Sep 10, 2015 | 10:22 PM
rolltidechris
Cruising
Thanks, that makes sense. I will see if I can get it figured out tomorrow.
To 1981 headlights
