New AC Harness Installation
My engine is out.. old AC harness is still in the car.. (burn scars and all)
Here's my plan..please critique..because I'm not sure if this is the best way to go.
1. Disassemble the dash to get access to the ac harness connections.
2. Replace the connections from the older harness with the connections from the new harness under the dash.
3. Pull the old harness through the firewall into the engine compartment and trash it.
4. Pull the new harness through the firewall into the engine compartment and reconnect after engine is in.
Thanks for your help with this.
I'd pull the right dash pad, the center dash bezel, shift plate and console. If you need help with this I've got a page at this link that will walk you through it. To view the pdf just click on supporting document.
[B]
1968-1977-corvette-dash-pad-remove-and-install-instructions
Willcox
