Is it possible to remove the headlight actuators on a 1979 with the hood on? I tried over the weekend with no luck. I have not yet tried with the hood lowered (just thought of that)... Maybe that would provide enough room to get it out of the bracket after removing the 4 nuts. I know it will fit out through the grill, once I get it that far.
I'm not that familiar with the later c3's, but on my '70 cars I was able to easily remove the cans by having an assistant hold the hood ALL the way open. This gave me much more room to extract them. Worth a try.....
they will come out the top but like Dave said , someone has to hold the hood all the way open. I also put some tape on the hood so it wouldnt scratch it, it is a tight fit but will come out the top.
I removed my actuators out of the front/bottom and it was easy. Now I know what I'm doing it takes me about 30 minutes a side to remove and replace an actuator. After disconnecting the vacuum lines I CLOSED the hood so I wouldn't scratch it. Here is the paint by numbers guide I used.
Great ideas, guys. I'll try them when I get back home this weekend. I don't know why I didn't try closing the hood while working on it last time, oh well. The idea of removing the support brace to open it further is good, too.
I have removed both my actuators from the top with the hood open and merely sitting on the lock that holds it open. I did tape heavily around where they came out and would have left plenty of scratches if I didn't. Mine is a 79 as well, BTW.
