vacuum tank
Old Sep 22, 2015 | 07:25 AM
chrissy t's Avatar
chrissy t
Default vacuum tank
I have a 70 vette and have been tracing the vacuum lines to check for a possible leak.The diagrams for the operation of this tank show two ports. My tank has 3 ports.Can someone please tell me what hoses go to the tank? Thanks, Rob
Old Sep 22, 2015 | 09:09 AM
Dave J's Avatar
Dave J
Rob, Off the top of my head....
1 - Input vacuum source from check valve
2 - Connect to "T" which splits between 1 H/L relay and wiper door relay
3 - Connects to the other H/L relay
Check out Willcox's site for a real vacuum diagram you can use.
Old Sep 22, 2015 | 10:17 AM
Iceaxe's Avatar
Iceaxe
Default vacuum tank
Yup, you need a better vacum hose diagram as the 70 tank has three hoses.
Old Sep 22, 2015 | 05:16 PM
chrissy t's Avatar
chrissy t
Thanks for the replies. After checking and double checking all vacuum hoses, turns out that I had a hose pinched by the steering column when I lowered it to check under the dash. Headlights would not go down, but ok now. Thanks again for all the help, Rob
Old Sep 22, 2015 | 08:33 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a copy if you need it again..
Old Sep 23, 2015 | 05:04 PM
chrissy t's Avatar
chrissy t
Thanks for the color version of the vacuum hoses. So much easier to understand. Thanks again, Rob
Old Sep 23, 2015 | 10:13 PM
0Willcox Corvette
Former Vendor
My pleasure Rob- Check out the repair help side of our site when you get a chance. http://repairs.willcoxcorvette.com/
Old Sep 24, 2015 | 04:58 PM
chrissy t's Avatar
chrissy t
lots pf useful info on you're website. I could not find the proper routing for the tcs solenoid.I disconnected it many years ago and now trying to get back to original. Thank you, Rob
Old Sep 26, 2015 | 05:37 PM
0Willcox Corvette
Former Vendor
This is all there is in the AIM.. Hope it helps.
Old Sep 27, 2015 | 07:36 AM
chrissy t's Avatar
chrissy t
looks easy enough to redo. Thanks again for the pic. I could not find it on you're website. Thanks for all the help and you will be first to call for parts.
Old Sep 27, 2015 | 11:10 AM
0Willcox Corvette
Former Vendor
I just put it up there yesterday for you, it wasn't on there....
To vacuum tank
