Problems from diff sitting for long period?
Old Sep 25, 2015 | 12:36 AM
Brad_B's Avatar
Brad_B
Default Problems from diff sitting for long period?
I have found a rear diff that looks to be what I am looking for. It is brand new and never installed, but has been sitting, with diff fluid, for approximately two years. Is there any potential problems with that? I would obviously change out the fluid prior to install.
Brad
Old Sep 25, 2015 | 01:04 AM
OMF's Avatar
OMF
The only real problem is moisture. If you live in a high humidity location, moisture can get in and cause corrosion on the bearings. I just bought myself a freshly rebuilt rearend and when I got it there was alot of sawdust chips inside (from sitting under the bench.) While cleaning it out, (with the ring gear removed), I noticed the corrosion on the bearing rollers and this lead to a total rebuild.....an enjoyable experience for me
If the rear cover is on you should be fine, but if not beware...
Old Sep 25, 2015 | 02:03 PM
Brad_B's Avatar
Brad_B
Thanks sstocker31. The seller said we could open it up when I got up there. I will do that for sure and see what I can see.
Cheers
Brad
To Problems from diff sitting for long period?
