Back Ground : Got a !979 350 from my grand father a month ago. its been sitting for 3 years. cranked monthly. prior to that sitting under a tree for 5 years somewhere. has been running perfect. drove it 2 miles to a shop. drove it 2 miles back.
Issue: Pulled in parking lot and cut out. cranked up immed. and then cut out. It felt like it had run out of gas. Filled it up with premium and nothing. Hit it with starter fluid and fires up immed then dies out. pulled the air cleaner off and poured gas directly in the carb and same thing. changed fuel filter in base of carb. still nothing. clogged jets?
Question: do i need to prime it some how. Im not very familiar with mechanical fuel pumps but was told if i wanted to replace it i would need to raise the moter several inches. I can buy a new pump no prob just dont want to waist any $. any suggestions
Try removing the fuel line going int the carb. Then crank the engine and see if gas comes out of the fuel line. If it does, then your problem is in the carb, clogged filter, jet, etc. If nothing is coming out of the line when you crank, then the problem is not the carb. Then disconnect the fuel line coming from the fuel tank to where it goes int the fuel pump. Gas should come out, since the line is lower than the tank. If it does, your problem is the fuel pump. If no fuel comes out, then there's a clog or restriction in the fuel line, tank, or pick up tube. You didn't say if the gas in the tank was 5 years old, and how much fresh premium you added. Did the old gas smell nasty? You may need to drain and clean out the fuel tank.
Fuel is new premium and drove good for a month.
No fuel at carb or fuel pump.
Removed fuel pump but am finding it difficult/impossible to hold the shaft back and slide the new pump on. Tried heavy grease per Hanes manual tried flathead, saw blade to prop it. It is just too tight it seems. May try taking the mounting plate off too
Thoughts?
Thoughts?
I replaced the fuel pump on my 79 a couple of times, due to high fuel pressure issues. I found that a second person comes in handy. I would get the rod pushed up and held up with a screw driver. With the second person holding the screw driver, I would get the pump into the block and manuever the pump arm under the rod (doing so from either the wheel well or under the car), and then have the second person pull the screw driver out.
Make sure that the crankshaft isn't in a position that is 'pushing' the rod towards the pump - that just makes it that much more difficult...
There are two bolts in front of the block right where the fuel pump shaft runs. if you take the bottom one out ( I think it's the bottom one) you can push the shaft up with the erasure end of a pencil. You can use a screw driver but be careful not to gaul the shaft. you can then hold the shaft up and slip the pump on.
