Lower ball joint bolts
Oct 8, 2015 | 08:38 PM
Question about the direction of the lower ball joint bolts.
Point them out? So the nut is on the outside where you can see it?
Or point them inside so you see the bolt head
Oct 8, 2015 | 09:00 PM
Bottom, one of the bolts should have a larger head as it's a turn stop
Oct 8, 2015 | 09:08 PM
Quote:
Originally Posted by
jeffreyluce
I installed mine with the nuts inboard.
One of the bolt heads is taller.
I put that one in the front hole.
Oct 8, 2015 | 09:45 PM
M
Oct 8, 2015 | 10:16 PM
Hmmm both same size
Both the bolts had the same head size, you can see from first photo.
I have the bolt heads on the outside and the nuts on the inside for now (picture 2)
Oct 8, 2015 | 10:40 PM
jeffreyluce
Need to get the correct bolt with the higher head - it is your turn stop for the wheels - prevents them from turning further.
Oct 9, 2015 | 11:22 AM
Not on Corvette. Corvette uses a different stop welded to the rear of the control arm and a raised area on the steering arm. All other cars use the stop bolt in the rear position. On a Corvette the large head bolt needs to be put in the front hole. In the rear hole it interferes with the factory stop.
Oct 9, 2015 | 11:33 AM
Those look like the wrong bolts. My Moogs bolts were not that long.
Oct 9, 2015 | 12:35 PM
2015 C2 of Year Finalist
ddawson
the head marks indicates a grade 3 bolt
Oct 9, 2015 | 12:57 PM
Oct 9, 2015 | 01:08 PM
tracdogg2
That would make sense as the originals are riveted on.
