Replacement horn suggestions
Old Oct 15, 2015 | 03:13 PM
EIGHTY's Avatar
EIGHTY
Default Replacement horn suggestions
I have a 1980...looking to replace both horns. One is weak and the other is dead. What are good replacements for the two horns? I'm seeing several options online. All ears...
Old Oct 15, 2015 | 04:06 PM
Wrecked82's Avatar
Wrecked82
Be sure to ask the forum if there are better places to mount the horns also. I asked and got no answers.
Old Oct 15, 2015 | 05:17 PM
Jack605's Avatar
Jack605
Air horns are nice.
Old Oct 15, 2015 | 05:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The cheap replacement horns you can get at your local parts store will work just fine. We always get 1 A note and 1 F note.... Makes the loudest horn combo you can get.
Some aftermarket horns require you to wire in a ground but that's pretty simple too. I always mount them where the factory horns were mounted, on the header bar in front. I'm not sure where I would mount them if I had to.... Possibly on the front of then inner fender...
-Willcox
Old Oct 15, 2015 | 07:29 PM
EIGHTY's Avatar
EIGHTY
-Willcox
Thanks for the help. I plan to mount them in the factory locations. A & F it is.
Old Oct 15, 2015 | 07:38 PM
slickfx3's Avatar
slickfx3
i ran into a set for 9.99 at harbor freight and bought them, yet to be installed
Old Oct 15, 2015 | 07:39 PM
EIGHTY's Avatar
EIGHTY
Found these listed at Autozone. Not sure which notes they are though. Will these work?
http://m.autozone.com/electrical-and-lighting/horn/blazer-horn/chevrolet/corvette/1980/8-cylinders-8-5-7l-4bl/268333_0_2499/?location=
http://m.autozone.com/electrical-and-lighting/horn/blazer-horn/chevrolet/corvette/1980/8-cylinders-8-5-7l-4bl/6071_0_2496/?location=
Old Oct 15, 2015 | 07:40 PM
EIGHTY's Avatar
EIGHTY
Keep me posted if you install them in the next few days!
Old Oct 15, 2015 | 08:14 PM
Richard454's Avatar
Richard454
I went w/ a set of BMW 7 series E38 horns (94-01). Super loud- made by Fiamm
A pair of these might set you back a couple hundred at the dealership- or about $30-40 pair on eBay- upullit auto parts maybe $20.
If you have ever heard a pair- this things are loud- that's why I went w/ two sets!!!
Tucked them out of the way -under each fender-
DSCN5124 by Richard Hayes, on Flickr
Old Oct 16, 2015 | 09:18 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Horn
If you are looking to keep your original horns, have them rebuilt. I used, The Horn Works, to rebuild the horns for my 70 SS Chevelle. They came out factory fresh and work as new. Jerry
Old Oct 16, 2015 | 09:25 AM
EIGHTY's Avatar
EIGHTY
I plan to keep the original horns so I'll probably end up getting them restored eventually. Thanks for the tip!
Old Oct 16, 2015 | 01:41 PM
mikem350's Avatar
mikem350
Tip...when mounting horns, orient the open end DOWN, so they don't fill up with water
Old Oct 16, 2015 | 02:27 PM
kjr6306's Avatar
kjr6306
Just curious. What does it cost to restore a horn??
Old Oct 16, 2015 | 04:55 PM
Tampa Jerry
Default Cost
You can check The Horn Works website for pricing. My pair were rebuilt for about $190. Jerry
To Replacement horn suggestions
