A quick update. I took the throttle cable off and no difference. I have managed to get the idle down to 550, but I am still not hitting against the idle screw when this low. I adjusted the idle at 700 rpms. I appreciate all the great tips and ideas.
Are you aware that the stock idle speed for a 1973 4 speed is 900 rpm?
no not using the solenoid, the throttle stop has not contacted the solenoid in the 3 years I have owned the car. Solenoid is a good 1/4 away from the stop at idle.
MelWff, although I appreciate your feedback, in the previous post I posted to answer your question
"no, not using the solenoid, the throttle stop has not contacted the solenoid in the 3 years since I have owned the car. Solenoid is a good 1/4 away from the stop at idle."
Why would I use or repair the solenoid if my car is not using it?
My carb doesn't hit the idle screw at idle either. That is the main issue I am trying to resolve.
Judging by the appearance of the carb, it has been rebuilt at some time. It's possible that the primary butterflies were not positioned correctly when reattached to the shaft. There might be interference preventing the shaft from rotating to a full "idle" position and causing your non-contact problem. Look down into carb and examine the position of the butterflies.
