Transmission advice
Old Oct 24, 2015 | 11:08 AM
timstrong20's Avatar
timstrong20
Default Transmission advice
Rookie C3 owner here. I have a 77 and it appears I have a trans leak. I noticed it wasn't shifting well and crawled under the best I can and noticed burned oil on the exhaust and small puddle under the car. It is a manual trans, think muncie m21. First, what oil do you recommend putting in it. Secondly where/how do put oil in it. Does anyone have a pic of the fill and drain points. I did order a CAM so I will have that eventually soon. Yes I do realize I need to figure out the leak, I just want to add oil before moving it much to inspect. Thanks again for any advice.
Old Oct 24, 2015 | 11:36 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Should a Borg Warner trans. I think last year for a Muncie was 74. Any 85/90 gear oil is all you need.
Old Oct 24, 2015 | 11:44 AM
409/409's Avatar
409/409
I don't think there is a drain plug. The fill plug is about halfway up on the main case on the passenger side. It should have a square head.
Old Oct 24, 2015 | 11:50 AM
Nowhere Man
That's how a pre 70 Muncie works. Not sure on B/W. If no drain plug your going to have to pump or siphon it out
Old Oct 24, 2015 | 01:16 PM
ddawson's Avatar
ddawson
Sta Lube 85W-90 seems the be the most recommended oil.
Amazon.com: CRC SL24229 API/GL-4 Multi-Purpose Gear Oil, 32 Fl Oz: Automotive Amazon.com: CRC SL24229 API/GL-4 Multi-Purpose Gear Oil, 32 Fl Oz: Automotive
Old Oct 24, 2015 | 01:57 PM
timstrong20
Thanks for the replies, how many quarts typically do they hold on a manual transmission. I was thinking 3, but not sure.....
Old Oct 24, 2015 | 02:23 PM
409/409's Avatar
409/409
About 3 pints. 1 1/2 quarts.
Old Oct 24, 2015 | 03:50 PM
ddawson's Avatar
ddawson
Yea, a little over 1 quart.
Old Oct 24, 2015 | 07:12 PM
timstrong20
Thanks for the replies, I will order/pickup some asap.
Old Oct 25, 2015 | 08:25 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Back in the day I was taught to pull the plug and stick I finger in the hole to see where the level is, it should be level with the plug hole. Problem is you have to have it level, not jacked at an angle.
Old Oct 25, 2015 | 08:38 AM
Nowhere Man
that is the proper way to do it.
Old Oct 25, 2015 | 08:56 AM
Wee's Avatar
Wee
Tim....If it's a muncie the drain and fill plugs will be on the passenger side.
Here is the best pic I could find on mine.
Brian
Old Oct 25, 2015 | 09:08 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Brian
Old Oct 25, 2015 | 11:25 AM
Type65's Avatar
Type65
You will likely find it is very hard to find a non-synthetic yellow metal and syncro safe gear oil. With that said I recently replaced the gear oil in my 77 with Redline MT90 and am very happy with it. It is so much easier to shift now especially when cold. You will have to drain all of the old oil if you are switching to synthetic though.
Old Oct 25, 2015 | 12:00 PM
croaker's Avatar
croaker
I want to say mine has a drain plug. Might be thinking about another
Old Oct 26, 2015 | 11:31 AM
timstrong20
Brian
Thanks for the pic, that is what mine looks like. I am going to try to get it lifted and level this weekend to drain and fill it. Also try to find the leak location. I think there might be a couple leaks since I found two small puddles, one is a little further back. Thanks again.
To Transmission advice
