This might be a dumb question
Old Oct 28, 2015 | 08:57 PM
COOLTED's Avatar
COOLTED
Default This might be a dumb question
Hello. I am taking my 79 to Kansas City next week on a business trip. The car with it's 3.55 rear will be spinning a lot of RPM's for 3-4 hours during the trip. Mechanically the car is just fine, but the high revs for an extended period of time makes me wonder if it's a good idea. I think everything will go just fine, but I'm wondering if high revs for such an extended period of time might be damaging in some way, it does run about 8 degrees warmer on the interstate.
GM built the car that way so it must be ok...right?
79 L48 54,000 miles, auto trans.
If I'm lucky, it will be warm enough to come home with the tops off
Old Oct 28, 2015 | 09:41 PM
lowbuck72's Avatar
lowbuck72
Running 3000-3500 rpm for an extended period will do no damage as long as your engine is in decent shape and doesn't overheat. The piston speed may be high, and you will get lousy fuel economy, but there won't be much load on the engine. Just to be safe, you may want to pull over after the first hour or two and check the oil.
Old Oct 28, 2015 | 09:45 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If putting taller rear tires on the car to drop the rpm by a couple hundred isn't an option........Take it easy on the car and yourself........Relax/listen to some good music and drive 60 mph.
Old Oct 29, 2015 | 01:04 PM
The13Bats's Avatar
The13Bats
My 69 with mild 454 and th400 will be a daily driver, lots of cats here say it can't be but I will do it anyway
In 79 lots of people took their then new Corvettes on all kinds of trips and since the rpm the engine ran was the way things were no one cared, my 81 had 100K miles on it by 88 and it was about 1/2 city to highway it didn't hurt the car.....if your car is in good shape it will do as well as it would have in the 80's when it was new....your fears are based in comparing the c3 to modern cars almost apples to oranges....
Old Oct 29, 2015 | 01:07 PM
COOLTED's Avatar
COOLTED
Thanks guys, you put my mind at ease. I figured it was no big deal, but I just wanted a little reassurance. 74 degrees forecast for Tuesday...tops off lookin' good.
Old Oct 29, 2015 | 05:01 PM
orourke's Avatar
orourke
Drove my 1973 with 3.55 gears from Ft. Lauderdale Fl. to Tulsa, Ok. with out a second thought. Filled the tank, jumped in it and went!
Old Oct 29, 2015 | 05:55 PM
Paul L's Avatar
Paul L
My former 1979 (still in family) has gone about 75,000 miles with the 3.55 rear and TH350 with no problems. Do not worry.
Old Oct 29, 2015 | 10:03 PM
gunnersguru's Avatar
gunnersguru
kc kansas or kc missouri
Old Oct 30, 2015 | 10:12 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Keep in mind that the speed limits back then were 55 which provided for cruising at a lower RPM and thus the selection of the gear ratios. Should be ok as long as you keep it to a respectable (did I say that) speed.
Terry
Old Oct 30, 2015 | 10:29 AM
Tom73's Avatar
Tom73
Engine should be okay but make sure all sub-systems are up to par. Drove my 73 L82 with 3:55s from central Texas to Bloomington Gold (14 hrs) and engine did okay but had to replace an alternator that went out about a quarter way into the trip.
Tom...
Old Oct 30, 2015 | 10:42 AM
joewill's Avatar
joewill
just think of the poor folks that have 4.11 or 4.56 who take their car on the interstate....
Old Oct 30, 2015 | 10:59 AM
COOLTED's Avatar
COOLTED
Missouri...by the airport. Going to be at the Toyota Parts Distribution Center.
Old Oct 30, 2015 | 11:04 AM
COOLTED's Avatar
COOLTED
[QUOTE=HOOAH;1590802264... keep it to a respectable (did I say that) speed.
Terry[/QUOTE]
lol
To This might be a dumb question
