1976 Wiring
Old Nov 10, 2015 | 03:30 PM
R51's Avatar
R51
Default 1976 Wiring
Hope someone can help me out. I have looked at the wiring diagram in the assembly manual and repair manual and can't find it. I have a purple wire that runs under the sill plate on the drivers side, does anyone have any idea what this wire goes to? it is separate from the main wiring harness that runs under the sill plate. Thanks
Old Nov 10, 2015 | 04:11 PM
oledave60's Avatar
oledave60
Do you have a rear window defog? That is the only purple wire that I see going to the rear.
Old Nov 10, 2015 | 05:12 PM
mayor28's Avatar
mayor28
Should be the rear defroster. Should terminate at the switch on the drivers side of the transmission tunnel about knee length from the pedal box.
Old Nov 10, 2015 | 06:18 PM
R51's Avatar
R51
I do have a rear window defrosted, Thanks. I will check it out. Doing my first corvette interior restoration. Could not figure it out. Thanks again.
To 1976 Wiring
