Hooker Side Pipes
Old Nov 17, 2015 | 10:47 AM
paso's Avatar
paso
Default Hooker Side Pipes
I moved the Hooker Headers and side pipes from my 76 to my 77.
What have some of you done to the chrome molding under the door?
It won't re mount as there is not enough clearance?
Looks like it needs to be cut and notched?
On the 76 I didn't install the chrome.
Old Nov 17, 2015 | 12:04 PM
REELAV8R's Avatar
REELAV8R
I reluctantly ended up notching mine. The fit varies from side to side. One side would not go on without the notches and the other side would, but was pushed out by the side mount bolts.
Old Nov 17, 2015 | 05:19 PM
TimAT's Avatar
TimAT
I used a 3" drum sander and opened mine up around the primary tubes. Got them fit, and still haven't put them back on. Other projects got in the way.
Old Nov 18, 2015 | 04:20 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
Very easy to cut them slightly might vary from side to side Or you may not have to cut them at all. Easy fix.
Old Nov 18, 2015 | 07:37 PM
Cavu2u's Avatar
Cavu2u
Paso,
The installation instructions address the cutting of notches for fitment. Let me know if you don't have them, and I, or someone here quicker than me, will post them for you.
Steve
Old Nov 18, 2015 | 08:05 PM
paso's Avatar
paso
Originally Posted by Cavu2u
Paso,
Steve
I didn't know they had instructions Steve, I bought them new over 10 years ago, so yes I think they would be helpful if anyone has them.
Old Nov 18, 2015 | 09:56 PM
Cavu2u's Avatar
Cavu2u
Paso,
Hopefully you can read these.
And hopefully these help.
Steve
Old Nov 25, 2015 | 09:27 AM
rangepony69's Avatar
rangepony69
When you put these on how did you hang your a/c and alternator?
Old Nov 25, 2015 | 11:15 AM
Cavu2u's Avatar
Cavu2u
If you're asking me, I've yet to install the pipes, or the factory A/C compressor.
Steve
Old Nov 25, 2015 | 11:42 AM
REELAV8R's Avatar
REELAV8R
I used threaded rod couple of nuts I think there's a spacer in there and then final nut to hold the bracket.
Old Nov 25, 2015 | 02:35 PM
rangepony69
Cool.....so no big deal....
Old Nov 25, 2015 | 03:14 PM
Cavu2u's Avatar
Cavu2u
Shuda thought of that before I bought this:
http://www.summitracing.com/parts/hok-65668xhkr
I'm lazy.
Steve
To Hooker Side Pipes
