Tachometer Inop
Old Dec 2, 2015 | 10:34 PM
Bneezey's Avatar
Bneezey
Default Tachometer Inop
I bought a 1979 Corvette with a 383 stroker motor with all MSD ignition. None of the original gauges work other than the speedometer and an aftermarket oil temperature and pressure gauge. But the one I'm concerned with fixing now is a tachometer. Is there any simple fix to get this gauge back? The RPM sits at zero and doesn't move at all with the engine is on or off and I was told that I possibly need to get a converter because of the MSD ignition. Any thoughts?
Old Dec 2, 2015 | 10:53 PM
ed427vette's Avatar
ed427vette
I'm not familiar with what was on the 79 engines but on earlier cars they used the tach drive distributor. If the distrbutor was replaced with an MSD unit then that is the problem.
There is a cable that runs from the tach and screws into the side of the distributor. If its disconnected, that's the problem. Take a pic of your setup, it will be easy to see.
As far as a solution, can't help. I'm sure there is a way or something made to convert it but I don't know.
Ed
Old Dec 2, 2015 | 11:02 PM
D_Williams's Avatar
D_Williams
I think they got rid of the tach cable in 75, but I'm not familiar with the electronic tach, so I wouldn't know where to start other than test if the tach wire is sending a signal to the gauge or not
To Tachometer Inop
