speedo gear
Old Dec 4, 2015 | 08:21 AM
vette_20's Avatar
vette_20
Default speedo gear
Hi just changed my diff to 3.5 can anyone tell me what color speedo gear it should have ,I have turbo400 and its standard rally wheels
thanks ian from aussie
Old Dec 4, 2015 | 11:53 AM
MelWff's Avatar
MelWff
the wheels are 15" but what diameter tire are you running? there are sites where the gear can be determined but you need to supply tire diameter and the 3.55 gear ratio,
Old Dec 4, 2015 | 04:57 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you know how fare off the actual speedometer is, you can make a tooth adjustment based on 1 tooth = 5 mph +/-.
According to the factory chart with the factory tires and wheels.. a 1975 with the turbo trans would use
Drive gear 8623310
Driven Gear 1362048 40 tooth black.
Willcox
To speedo gear
