Steering Linkage - Help!
Old Dec 13, 2015 | 08:37 AM
PBCloud's Avatar
PBCloud
Default Steering Linkage - Help!
1970 454 Corvette.
Sorry to ask what is probably a very silly question but I have not tackled this job before.
I am trying to remove the power steering cylinder, I have removed the pin from the screw thread at the threaded end that connects through the steering relay rod, but the nut turns without unscrewing what do I need to do, I notice a grease nipple on the opposite side does this need to be unscrewed with its cover to get at a hidden bolt head?
Regards
Paul
Old Dec 13, 2015 | 09:00 AM
jnb5101's Avatar
jnb5101
Are you referring to the nut on the relay rod, or the attachment at the frame bracket? I believe there is a "flat" on the end of the cylinder rod where it passes through the frame bracket. If it's the relay rod end, tap on the back side of the cylinder to seat the two pieces together. That should keep the threaded part from rotating.
Old Dec 13, 2015 | 10:05 AM
PHIL 68's Avatar
PHIL 68
the whole purpose of the cotter pin hole is to prevent nut from turning when something is in it, just saying Phil
Old Dec 13, 2015 | 10:10 AM
mds3013's Avatar
mds3013
Yeah, I got it wrong. Stud may need to be reseated or nut or stud could be stripped. I hope not. mike...
The connection in question is in line with the oil pan in first pic.? Connection is similar to second pic.? I will let the other guys make suggestions. mike...
Old Dec 13, 2015 | 01:15 PM
PBCloud's Avatar
PBCloud
Default Thanks for your help
Its the other end of the power steering cylinder, at the right side as you sit in the car (not the end near the driver front wheel), where it is linked to the relay rod through a hole at the end of the cylinder. There is a nut on a threaded section here that fixes them together, the threaded section and nut are turning together, and the nut not unscrewing.
Diagram attached.
Old Dec 14, 2015 | 03:43 AM
PBCloud's Avatar
PBCloud
Default Photo
How do I add a photo of the problem to this thread?
Paul
To Steering Linkage - Help!
