mice in the heater
Old Dec 19, 2015 | 06:07 PM
ronarndt's Avatar
ronarndt
Default mice in the heater
I am finally getting around to the less essential repairs on my 68 convert. Decided to fix the heater, which the PO had completely disconnected. When I removed the heater box enclosure to check the heater core, I found where Mickey and Minnie had set up their little home at the PO's place. Why do they always go for the heater?
Old Dec 20, 2015 | 08:08 AM
RS69's Avatar
RS69
Yep, similar issue for me too. I pulled my heater core out years ago and had the same situation. I used poison in the past, but it seems the mice would die in areas my 69 which caused me more time to remove the parts to get to them(bad smell). I use Irish spring soap, moth ***** and old style mouse traps for my defense.
When I painted my 69 this past year, I found out the mice had some nice homes in my door panels too.
Old Dec 20, 2015 | 08:38 AM
red topless gator's Avatar
red topless gator
We have used bounce sheets the last couple of years and have had no more problems.
Old Dec 20, 2015 | 08:52 AM
toylman's Avatar
toylman
When I changed the heater core on my 1970 I found them in the same place. They were snacking on the blower fan as well. The good thing was that my dash wiring was not touched. I now use the fabric softener sheets like Gator.
Old Dec 20, 2015 | 12:00 PM
mickey5's Avatar
mickey5
Found a nest twice the size of a softball in the jack cubby of '74 roadster I recently acquired. I found the rubber drain tube was missing which made it easy for the critters to get in.
Old Dec 20, 2015 | 07:23 PM
Bills17n72's Avatar
Bills17n72
I buy three bars of irish spring soap ,cut it up in small pieces and spread the pieces around the tires ,mice do not like the smell of that stuff,been doing it for years!!!
Old Dec 21, 2015 | 07:46 AM
CPTCroaker's Avatar
CPTCroaker
Used to put moth ***** in the car over winter storage. Kept all the critters out but needed to be aired out before driving again. Dryer sheets sound much more pleasant.
Old Dec 21, 2015 | 10:51 AM
midigike's Avatar
midigike
Found them mice skeletons in the #2 body mount on mine when I did my inspection, they also chewed a hole in the battery box too, I hate vermin
To mice in the heater
