Oil pressure, what's normal ?
Old Dec 31, 2015 | 03:12 PM
killain's Avatar
killain
Oldtimer
Default Oil pressure, what's normal ?
What's a normal oil pressure in my 77 350 ?
Old Dec 31, 2015 | 03:17 PM
JimLentz's Avatar
JimLentz
Mine runs around 20 at idle with the specified 10W30 oil. When cold it is around 40 at idle and goes higher while driving.
Old Dec 31, 2015 | 03:19 PM
c3_dk's Avatar
c3_dk
My 69 with 20W50 is 35 when hot and driving.
Zoix's Avatar
Zoix
Oil pressure varies as follows:
At startup cold above 30 psi is normal at idle.
Warm at idle 12 - 20 psi.
Warm above 2000 rpm 30 - 40 psi.
All approximate with factory pump.
Old Dec 31, 2015 | 04:01 PM
Tom69's Avatar
Tom69
2018 C3 of Year Finalist
Same.
Old Dec 31, 2015 | 04:15 PM
killain's Avatar
killain
Oldtimer
Default So said . . .
Guys have told me that you need about 10 PSI for every 1000 RPM. Does that sound about right, and what do you think of Hi-Volume oil pumps ? Good or bad ?
I ask because I have a lot of boat marina's here with I live, ( You can see the Delaware River from my porch,) But some of the guys who overhaul a lot of the engines in the bigger 35+ foot boats that too much pressure can cause some of the engine to start leak oil where a stock pump wouldn't except that fault. But it all depends on what kind of build you want in the engine/s'
But most of the bigger boats run 454 V8, and the older boats have 327 V8 in them.
Old Dec 31, 2015 | 04:57 PM
MelWff's Avatar
MelWff
10 psi/1000 rpm is the minimum number. Why do you feel you need a high volume pump? The stock Chevy pump on the 70 to 72 LT-1 put out as much as 70 PSI at high engine speeds.
Old Dec 31, 2015 | 05:11 PM
killain's Avatar
killain
Oldtimer
Default Oil . . . I was just wondering
I was just wondering I have about 12 psi at idle in drive and about 35 @ 65 MPH or 2300 RPM. I have a stock 350 and it's a 77 Corvette, the lowest in the horsepower years where the government had it's talons deep in GM and all other manufactures to the point where some of the truck engines were more able to power a 3400 pound car.
Old Dec 31, 2015 | 05:33 PM
diehrd's Avatar
diehrd
I idle at 40 hot and 70 at speed .. I would freak out if i had 12psi LOL.
But if all is well I would not touch a thing until you have to or do a rebuild on the motor .
Old Dec 31, 2015 | 05:51 PM
killain's Avatar
killain
Oldtimer
Default Thank you !
Yeah, she's got 139.000 on the clock, but I have had a lot going on and I'm thinking of getting a GM crate engine to replace the tired L-48. But it don't knock or burn too much oil, so I'll hold on. It's paid for and I keep it in one of my garages.
Thank you and have a great new year, May your health sustain you onward and outward. Happy New Year. And I'm able to be a designated driver if you are near me. Philadelphia area. And this year I have been blessed now with 30 years sober. And there was a time I didn't think I could make it 30 minutes with out a drink. Be well !
Old Jan 1, 2016 | 11:30 AM
MelWff's Avatar
MelWff
have you considered testing the accuracy of your gauge by renting or buying a hand held pressure gauge? you make no mention of what oil you use but may want to consider a 10W40 with a zinc/phos additive.
Old Jan 1, 2016 | 02:50 PM
CaptTeo's Avatar
CaptTeo
Cruising
I am about the same as Diehrd on my 77. It stays about 30-35 at idle and 70 while running. I changed the breathers and vacuum lines recently when I redid the carb and now have a smaller breather and it bumped up about 5 psi while running to 70.
Old Jan 2, 2016 | 02:33 AM
13611's Avatar
13611
Congrats on the 30 years brother!!!
Old Jan 2, 2016 | 05:45 PM
killain's Avatar
killain
Oldtimer
One day at a time, I'm only as good as yesterday ! But Thank you !
Old Jan 2, 2016 | 07:58 PM
forvicjr's Avatar
forvicjr
I have a 434 sb thats currently moth balled. I have nothing to put it in. It has dynoed 785 hp at the flywheel. I took my time blue printing and was meticulous with the clearances. I built the motor on the tight side and wound up with some crazy high pressures. I personally dont mind high oil pressure as if you hurt the motor it will show fairly easy. It is however rough as hell on bronze dist gears and ac delco oil filters.
Idle cold 1100 rpm/ 90 psi
3500 rpm cold/ 125 psi
Idle hot/ 70 psi
3500 rpm hot/ 95 psi
Old Jan 13, 2016 | 05:29 PM
killain's Avatar
killain
Oldtimer
Default Help. . . I need some technical help.
Thank you, I didn't think of that. I have a mechanical gauge setup, but I have just finished installing a new sending unit, a new dashboard gauge itself and am waiting for parts to finish this project.
Thank you !
Old Jan 14, 2016 | 10:39 AM
mickey5's Avatar
mickey5
Just acquired a '74 L48 with 38K original on the clock. Would appreciate your thoughts on what viscosity and brand of oil to use.
Please excuse using this thread but while your on the subject.....
To Oil pressure, what's normal ?
Old Jan 14, 2016 | 11:46 AM
Hammerhead Fred's Avatar
Hammerhead Fred
This oughta keep you busy
Old Jan 14, 2016 | 12:00 PM
killain's Avatar
killain
Oldtimer
Default Oil Loyalty ?
I have always used Mobil oil. I use it in my 1990 Chevy pickup and in all the other cars. Same goes for the 2014 GMC terrain I bought last year. It takes synthetic so I use the same Mobil-1 as in the corvette. It's my opinion, and that it is, I've never jumped brand to brand.
Back in the seventies, there was a oil manufacture who mixed Graphite in with the 10W30 weight oil and I assumed it seemed like a good idea. But after a year you had an engine with it's oil galleries clogged solid. The blocks and heads had to soaked in solvent to break the graphite loose and then flush the CRAP OUT. Then you can get on with a rebuild.
Old Jan 14, 2016 | 01:34 PM
mickey5's Avatar
mickey5
Originally Posted by Hammerhead Fred
This looks like a real bag of snakes. All I'd like to do is go to Walmart or Costco and pick up some oil to change it this spring. Is anything available that's noted in the thread at an auto parts store like Pep Boys or Advance? Is there any problem besides leaks going from dino to synthetic?
Sorry OP for all this chatter..perhaps I should have started a new thread.
