VIR rebuild
Old Jan 4, 2016 | 10:33 PM
Omarsvette's Avatar
Omarsvette
Default VIR rebuild
anyone know how to rebuild the VIR on a 73? i have seen the kit on docrebuild. just don't know how to rebuild it.
Old Jan 5, 2016 | 10:44 AM
MelWff's Avatar
MelWff
contact the distributor directly
http://www.oldairproducts.com/catalo...ette&Year=1973
Old Jan 5, 2016 | 10:46 PM
Omarsvette's Avatar
Omarsvette
thanks that work
Old Jan 6, 2016 | 09:10 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you are going to run R12 you can do it.. If you are going to use 134A it won't work. The POA for the VIR system was only designed for the R12 freon and R12 pressures. 134A is a different animal.
You'll also need two special tools to rebuild it.. if you look you can probably find them on ebay.
You can buy the rebuild kits direct from old air.. and it might be worth your time to give them a call about the issues with 134a.
-Willcox
Old Jan 7, 2016 | 05:25 AM
Omarsvette's Avatar
Omarsvette
i was told to use 134 i needed a different/bigger condenser (not by old air). is this true? what special tools are you referring to? old air said the kit is straight forward, replacing two canister seals, the bag, and a pick up filter. they don't sell anything for the valve. they said those rarely go bad.
Old Jan 7, 2016 | 05:25 PM
0Willcox Corvette
Former Vendor
The valve rarely goes bad... and the last time I needed one I found it on flea bay.. If you are not replacing the valves you won't need any tools. It takes two tools to replace the expansion and poa valves inside... For the record, the tools are Kent Moore p/n J-24181-1 (for the expansion valve) and the other is J24181-1 for the POA.
The bad part about this is the POA won't handle the pressures from the 134 system... Me personally working on a customers car... I don't like taking a chance with either valve and I try to replace them.. (only if the guy is running r12) It's a hard road for you guys with the VIR systems.. The by-pass kits have had their bumps in the roads too.. You'd be be better served going with a bypass valve and switching it over
IMHO-
Willcox
Old Jan 8, 2016 | 12:35 AM
Omarsvette's Avatar
Omarsvette
the rebuild kit has only two big rubber seals. but the vir has 3. two to the canister, and one on top lid. only the canister seals get replaced? and there is also a little o ring,were does it go? and the 6 prong washer? thanks.
To VIR rebuild
