1973 air cleaner
Well I can't get your pics to play . The only pic I see is facing the wrong way for me to tell ya.
There are three parts for BOTH engines....base , ring , and rubber seal .
The base and the rubber seal part are the same SB and BB.
Difference is in the RINGs . The INSIDE edge is where the diff is between the two rings .....the BB lip ring is offset on the inside , but still round on top.....this allows the 454 which sits different from the 350 to mate up with the air induction hood .....so there is just one hood for all cars. Cheaper to make two separate rings than two separate hoods.
You have to see the inside of the ring to see the difference. Look down on both .....and it's easy to see ....I can t tell from that one front view you show....the other five don't play
The BB ring is OFFSET inside ....the front is like 1 -2 inch wider at the inside flat edge facing toward the front of engine. The back inside lip is very narrow with maybe 3/8 " lip for the BB ring.
The SB inside ring lip surface is uniform 360 degrees . Inside and out
It's stupidity easy to tell once you see the BB ring. Not so easy to describe how to tell
LS4 BB ring is kinda rare . ......you might find somebody on eBay selling a BB ring with a base and they don't know what they got .....and get it cheap . But if a dealer gets one .....know what he has......then he'll sell it with a nice base and want 350-500 for the setup.
metal flange for the L48/L82 is part #330525;
LS4 is part #330527.
Donnie
I doubt they will tool up to make this part ......cost too much to sell a few .
Otherwise the dealers want big money for the ring .....and generally make you buy the whole deal
Did you look in the assembly manual. Both part numbers are in there .
Many of the BB parts are not reproduced and when they are , they are wrong and of poor quality.
its so hard being a pilot to an LS4
i guess ill have to use a sbc ring for a while.
