dumb question on cooling system
Old Jan 22, 2016 | 06:24 PM
mrc utx's Avatar
mrc utx
Default dumb question on cooling system
hey guys, maybe a dumb question but 2 engineers at the office couldn't answer it..
If when the thermostat is closed the water pump circulates coolant through the engine only, why doesn't it push some of the coolant through the lower radiator hose? The thermostat only closes the upper radiator hose, what keeps the lower one closed?
Thanks!
Old Jan 22, 2016 | 06:41 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Thanks!
Lower hose is the supply/suction side of the radiator.
Nothing to draw until the thermostat opens.
Old Jan 22, 2016 | 07:04 PM
flyeri's Avatar
flyeri
Water does circulate through the engine if there is a bypass hose installed. There is no circulation to the radiator through the top hose until the thermostat opens. Then coolant moves to the engine through the lower hose.
To dumb question on cooling system
