Owned my '73 cp 454 4spd now for just short of two years. When I bought it the PO had installed an Ederbrock 650cfm square bore carb. Never ran very well so I decided to buy the Holley 4175 spreadbore 650cfm. Performed quite well but I decided that it was not great and I am returning car to near original state. Well enter a $30 Rochester Quadrajet from a '77 truck w/400ci in need of a total rebuild. Bought the parts that were needed including jets and rods to match '73 454 specs. I have to say I was pleasantly surprised to the performance this thing has. Great throttle response and nice torque at all speeds. Carb and parts I may have $150 invested but the best bolt on I've done so far.
Its hard to beat a good Q-Jet on a stock engine. They provide excellent low speed response with the small Primaries yet good power with the large secondaries.. Will work on a wide range of engines...Hard to beat their MPG too. Reliable as well. Especially on Automatic Trans cars
Did you re-size the main air bleeds as well? I don't know off the top of my head what size rods and jets either carb had, but changing rods and jets alone w/o changing main air bleeds could cause you to be running quite lean, although 73 may have been late enough that they had already went to larger MABs.
I'm monitoring the spark plugs and so far so good. The car is running so well that I'm afraid if I try to modify anything I will start going backwards.
Do you know what the jet/rod combo was before and after?
I'd also be curious about MAB size between the two carbs.
Just curious, what intake manifold does the engine have? "Square bore" carbs don't interchange with a "spread bore" intake manifold, or vice-versa.....
I run the stock manifold. The Edelbrock came with an adapter plate. The Holley 4175 is a spreadbore, Holleys answer to the Quadrajets.
