Master cylinder 74
Old Jan 31, 2016 | 06:23 PM
swensonm's Avatar
swensonm
Default Master cylinder 74
I just replaced the MC on my 74 w/ pb. was bleeding all ok then started hearing air escape from between the MC and booster. I did not see a gasket when I removed or for sale at parts store. Is this normal or is the booster bad..thoughts?
Mike
Old Jan 31, 2016 | 06:40 PM
Gweesh's Avatar
Gweesh
Mike
Is vacuum escaping from booster with engine running or while vacuum still present in booster (pedal hasn't been pumped since engine off) or are you hearing air moving when pushing pedal with engine off and vacuum used up? Hopefully the diaphragm didn't rip when you changed masters.
Old Jan 31, 2016 | 07:05 PM
swensonm's Avatar
swensonm
I am hearing air escape when I depress the brake with out the engine running.
To Master cylinder 74
