Looks really good. You don't happen to have a before picture do you.
I do not. Never thought to do before and after pictures. The shifter is basically the same as the original just 2 1/4 inches shorter. About the diameter of the ball is how much higher it would look. No matter what length stick you buy about 4 3/8" goes below the console level.
The horn button was light saddle in color and had the same peeling condition as seen below the ignition switch. I went with black in re-conditioning to match the original steering wheel.
These were the final 2 winter projects I had. After new tires, new brakes, rebuilding the PS control valve and slave cylinder and a full under carriage lube job, I am ready for Spring.
Drive safely this year and have fun.
Jerry
Are you running a comp plus or super shifter? Noticed your console is modified and wondering if the tunnel is too. I am looking at several hurst shifters and not sure which way I want to go.
