Hood wont open
Old Feb 16, 2016 | 03:49 PM
Denpo's Avatar
Denpo
If nothing works, there's still a way by removing the front wheel, and unbolting the hinges from the hole in the wheel well that's covered by the rubber flap.
It's tight but doable.
Once the front hinge are unbolted you can pry it open the hood from the front and get a good reach a the latches.
Don't ask me how I know
Old Feb 16, 2016 | 03:57 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by jim in oregon
ON my 78,IF you peer beneath the hood past the windshield cavity where the wipers reside, there is a 1" rubber plug that yiou can push thru into engine compartment and then access the release mech under the rear of the hood left side or right..aTakes a flat blade screwdriver bent at an angle to get the mech contact a stretched center cable or hood to interior cable push down to release.Easiest to do if you have examined under hood with hood open..check utube for a couple of good videos on this..jim
I did this exact thing on a 76' not but three weeks ago......I used an old antenna with a small bend in it to push the latch/catch and release it.
Works like a charm.....
Jebby
Old Feb 16, 2016 | 07:16 PM
AirborneSilva's Avatar
AirborneSilva
Originally Posted by ronarndt
Please post if you find a good fix. My 68 convert had the passenger side pop open until I adjusted the "stop" that the hood part of the latch rests against to close about 1/8 inch smaller. Now the hood occasionally hangs up on one side (varies) and requires a second attempt to open.
Will do
Old Feb 16, 2016 | 07:20 PM
AirborneSilva
Thanks Jebby and Denpo, I'll let you guys know but it may be a couple more days, my Airborne days are reaching out and touching my back so I've been snacking on anti inflammatories and muscle relaxers
Old Feb 16, 2016 | 07:33 PM
DonnieP73's Avatar
DonnieP73
You can see the driver side release here on my 73.
Remove the plug and you can push on the tab to release the latch.
Donnie
Old Feb 16, 2016 | 07:39 PM
AirborneSilva
Thank you Donnie, that's my plan - wish me luck
Old Feb 16, 2016 | 10:15 PM
Lakeside49's Avatar
Lakeside49
Originally Posted by AirborneSilva
Any ideas on getting a stuck hood open? I've got the passenger side to release but can't get the drivers side
Here you go.
Dave
http://youtu.be/Z4BhkZ26nTQ
Old Feb 17, 2016 | 02:22 PM
AirborneSilva
Originally Posted by Lakeside49
Here you go.
Dave
Thanks Dave
Old Feb 19, 2016 | 07:20 AM
AirborneSilva
Denpo, I've looked up into the engine bay through the hole in the wheel well but can't see the bolts, do you have a picture of where they bolt onto the body? Thanks Brother
Old Feb 19, 2016 | 10:38 AM
jim in oregon's Avatar
jim in oregon
Abthony...
HEY, Call my son Joshua 520-822-7593 .He's USAF MSSGT living-stationed in San ANTONIO/Lackland.Currently MTI there.
he's an aircraft mech and motorcycle racer-builder and has seen my '78.Corvette..We've spent a few hours under the hood..
He would come by and assist you getting the hood open..HE's an excellent mechanic and smart-personable......
ACCESSING the release mechs via the two plugged holes in the engine compartment to wiper tray area is THE WAY the Chevy shop guys would open a stuck-damaged hood back when..IF you cann my son tell him his Dad in OREGON GAVE you the number...Once you get the hood open he can also help get the cross cables and mech properly adjusted-tensioned so THIS never happens again....Jim
Old Feb 19, 2016 | 10:51 AM
AirborneSilva
Abthony...
Thank you Jim, I'll give him a call... On a side note, it looks like he's spent time in Sierra Vista AZ, I have the same area code for my cell phone as well, never changed it after moving away from there... Thanks again
Old Feb 19, 2016 | 11:10 AM
ronarndt's Avatar
ronarndt
Default stuck hood
I got to the front hinge bolts on my 68 reaching up thru the front grill. My arm was just barely long enough to get a wrench on the bolts. As soon as I loosened the last one and moved the hood slightly, the stuck latch snapped and released. This method works, but is a PIA and then you still have to get the hinge bolts back in and align the hood without scratching the paint. Another GM engineering mystery designed late at night after a couple six packs.
Old Feb 19, 2016 | 11:24 AM
  #33
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
No mystery. The engineers put the two plugs in the firewall to gain access under the hood.
Old Feb 19, 2016 | 11:29 AM
  #34
jim in oregon
Anthony,Davis Monthan Tucson, Aviano, Serbia, Korea,Iraq Afghanistan.He still has his AZ DRIVER'S LICENSE.. DO give him a call..He'll help get this small but tricky task done for you..He's a great Son..jim
Old Feb 19, 2016 | 11:36 AM
  #35
vettebuyer6369's Avatar
vettebuyer6369
OK, first... no laughing.
This is embarrassingly "Bubba," but when I was a 20 year old kid in 1977, I bought my first C3, a '68. The car was iffy in a number of ways, one being the hood would fail to open periodically on the driver's side. Being a dopey kid, I figured out that if I pulled up on the hood a bit and slid a strategically bent butter knife in the opening, towards the WS (LH), I could trip the latch every time.
I actually kept a homemade tool in the car for such occasions. I also found that layiing on the ground with a very long screwdriver I could do the same thing, but I needed proper light and not be on the side of the road.
Disclaimer... this works great if the car's paint isnt perfect, but if not you need to be careful... if you are aggravated and not careful, you can scrape the paint on the fender ledge. I offer this as a method that worked, thinking there might be an easier, cleaner, safer way to do it better.
Went out to my old tools pile and 40 years later, it's still there!
Old Feb 19, 2016 | 01:29 PM
  #36
AirborneSilva
I just got off the phone with Joshua, great young man He's going to come by my house this afternoon to see if we can get this darn thing opened. Thanks all and I'll let ya know how it turns out
Old Feb 19, 2016 | 01:47 PM
  #37
Brandons72vette's Avatar
Brandons72vette
Good luck and nice tool VB!
To Hood wont open
Old Feb 19, 2016 | 02:18 PM
  #38
jim in oregon
Good deal, give him a hug for his Dad. Have him give me a call and I can explain the proceedure to him....IF you have a propane torch and a vise and a 12-14" cheal flat blade screwdriver the tool can be bent easily once ya envision how it needs to extend thru under the hood thru the hole..
All the best..De Opresso Liber! Sua Sponte..
And Attend to the cross cable tension..Mine was stretched after near 40 years and so I shortened it one inch..lubed all of course..Jim
Old Feb 19, 2016 | 02:22 PM
  #39
AirborneSilva
Special Forces? I was 82nd...
I'll have him give you a call, I wish I had a vice, I do have a small torch if I have propane for it is another question all together.
Airborne All The Way!!!
Old Feb 19, 2016 | 02:27 PM
  #40
jim in oregon
ONCE heated, one can hand bend the steel into shape.Vise just makes it easier....g
one last tidbit..Windshield wipers may be in the way to access the plug-hole ....you needn't remove the wiper arms..Just Start the wiper and turn ignition off When they are upright and out of the way..Jim
