Steering Column Question
Old Feb 16, 2016 | 09:35 AM
SideWinder3355's Avatar
SideWinder3355
Default Steering Column Question
I'm back working on my steering column and have a question. Where can I get the plastic sleeve that wraps around the wires that run to the turn signal switch? Mine is not is good shape and cracked in a number of places.
Gus
Old Feb 17, 2016 | 10:52 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have one in stock. According to GM there were differences between tilt and not tilt.. but the difference was the tele was shorter. The one I have left in stock is a non tele cover (1969-1977)so you'd have to cut it off if you had tilt.
https://willcoxcorvette.com/steering...969-1977-26587
Willcox
Old Feb 22, 2016 | 10:38 AM
SideWinder3355
Willcox
I ordered it on Friday. I have a standard column so it should work without modification.
Thanks for the help.
Gus
Old Feb 22, 2016 | 03:47 PM
0Willcox Corvette
Former Vendor
Okay Gus... thank you for the order!
To Steering Column Question
