1970 front clip
ZIO
call Austin 606 224-4645 he as a studder s be patient
their e mail Vettearn1956@gmail.com
steve
Since you have a 73 nose now, you will also need a front bumper for about $400, this is for the US made repro, which is the only one that fits correctly. You'll also need 69-72 front bumper brackets, for about $200, 70 grills which run about $1300 for the new repro's, or $700-$1000 for nice used original ones. New bumperettes are about $350 a pair. You'll be able to re-use the headlights from the 73 nose, but you'll need new marker lamps, at around $50 each, and you may need a core support and radiator, depending on what's in the car now.
If you have a 73 nose, you probably have the long 73 hood, that eliminates the 70's wiper door assembly and grill. If so, figure at least $500 for the wiper door and parts. The lower valance and front air dam, will need to be replaced also, since the 68-72 pieces are different than the 73 up ones.
Obviously, if you can find a complete used nose, you'll have less to buy to complete the swap. Personally I would try to find a 70-72 nose. The 68-69 nose is similar, but the side louvers, side marker lamps, grills, grill brackets, grill moldings and bumperettes are different, plus the body work needed to change the side fenders.
I've got to figure the labor to pull the old nose and hang the new one, could be in the $2000-$3000 range, and maybe more for a used nose that needs work. You can expect to pay as much as $10,000, for a quality repaint of the whole car, here in the "Northeast".
We've narrowed down your location from the Northeast, to PA, but where in PA are you? PA's still a pretty big state. I can recommend a number of very capable Corvette shops, in the Eastern PA and Southern NJ region, but that won't help you much if you're in Erie.
but.. you will have about 22K into it for a big block original motor with brand new paint.. might be worth it..
this might be a case where you actually get a discount on the car from the price that it will take to make it correct.
also. it cannot be an original M22 tranny.. they didn't come on 1970 big blocks (ZR1 only)
