I have a 1970 L46 4 speed manual tran Corvette. When I run through the gears and at 3000 to 3500 rpm's I am experiencing vibration in the stick shifter. The vibration is also noticeable when cruising at around 65 to 70 mph. I would appreciate any information you could provide me on what is causing this issue and how to fix it. Thanks
Could be the pilot bearing. Did you have new U joints installed on the drive shaft? I had a 72 LT1 that developed a vibration after I changed the U joints. Upon investigation, I discovered that the joint to the rear end I had installed with the grease fitting facing the pinion. This allowed the casing hump to touch the pinion shaft every revolution. Just lucked out finding that issue.
Good luck.
I actually only installed the new T-handle and spring and it cured 90% of the problem. I'll finish the project when I get more time and I'm guessing it will fix the remaining buzz problem.
There is also a cheat/bubba fix you can use for the time being which is simple, cheap, takes about 2 minutes to install and works surprisingly well.
Unscrew the shift ball and pull off the spring and T-handle. Then get a small O-ring that fits snugly on the "step" on the lever below the T-handle seating area, then re-install the T-handle, spring, and ball. The O-ring will stop much of the vertical buzz between the bottom of the T-handle barrel and the "step" on the lever. It's well worth the 15 cent O-ring.
Hi guys. While you are pondering this vibration issue, I would like to jump in with my problem also.
I have a newly acquired 1970 L46 convertible, that is having vibration issues at the mid range revs (3,000 - 3,500) and on up. It does not matter if you are stopped in neutral or rolling at 60 -70. Push on the gas, and you get vibration through the seat, and up through the stick..
I got past a timing challenge at idle, but still not sure if it is missing later as the revs go up.
I had this issue in the past with a ‘67 Camaro also a Muncie. The car was run at the strip a few times and vibration as you describe. Ended up being a sprin/tweaked input yoke on the rearend. The problem could be virtually anywhere in the drivetrain. Replaced the front yoke and problem solved. Obviously it did not vibrate at a standstill.
original 4 speed corvette shifter mounts to the frame, not the transmission, this should eliminate most driveline vibration.
(aftermarket / Hurst) mount to the transmission, much more prone to transmitting drive-line vibration.
Very good point but the shifting rods attached to the trans go to the shifter.
