Stock Wheel to Custom conversion
Old Feb 22, 2016 | 11:31 PM
Storm059's Avatar
Storm059
Cruising
Default Stock Wheel to Custom conversion
My Stock rims on my 81 are all 15x8. one is bent a little and wont balance. it is next to impossible to get 15 tires where I live. i want to convert to 17 inch and my question is do I need to change anything with the brakes also do I need to worry about offset. What off set would I need?
Old Feb 22, 2016 | 11:37 PM
3JsVette's Avatar
3JsVette
The stock 15" wheel has a 4" backspace. The stock tire is 27" tall.
If you go with a 17" wheel that is 8" wide stick with a 4" backspace.
If you want to stick to a 27" tall tire a 255/50-17 will be the same height.
Stick to backspace as opposed to offset it keeps things much easier.
I hope this helps.
Old Feb 23, 2016 | 12:00 AM
gbvette62's Avatar
gbvette62
I don't know where you're at, but Cooper and BF Goodrich, offer white lettered tires in both of the 81 OEM sizes, P225/70R15 and P255/60R15.
To Stock Wheel to Custom conversion
