Noises when I punch it
Old Mar 9, 2016 | 08:52 AM
Bunkers 70's Avatar
Bunkers 70
1st Gear
Default Noises when I punch it
I have a 70 vette. When I get on it pulling out I hear a sound like something is rubbing. She squats pretty far but I can't find any evidence of rubbing. It does not sound like wheel rub. I was wondering if the suspension is too soft and if so (since I'm on a serious budget right now), what might be an easy inexpensive solution.
Thank you
Old Mar 9, 2016 | 09:05 AM
bashcraft's Avatar
bashcraft
Thank you
Until you find out what's rubbing, no one can give you a solution.
Could it be a wheel bearing?
Old Mar 9, 2016 | 01:34 PM
blue by you's Avatar
blue by you
could be the clutches in the posi maybe change the fluid and add the posi additive
Old Mar 9, 2016 | 01:53 PM
COOLTED's Avatar
COOLTED
You could also check your motor mounts. Check the fan shroud. Bad motor mounts can cause the fan to hit the shroud.
Old Mar 9, 2016 | 03:53 PM
MelWff's Avatar
MelWff
Is this car an automatic or a manual? Have you checked the front rear end support bushings?
Old Mar 9, 2016 | 04:02 PM
fishslayer143's Avatar
fishslayer143
You need to get under the car and under the hood and look at everything that rotates... if something is rubbing, there will be telltale evidence of it.... it could be one or more of many things ... jack it up and start looking with a flashlight
Old Mar 11, 2016 | 10:27 PM
LS4 PILOT's Avatar
LS4 PILOT
The single big rear suspension bushing .....maybe called the snubber ?....it's a big donut sized bushing ......if it wears out you can get all,kinds of vibrations, rubbing sounds , stuff that sounds or feels,like issues in the diff........if your vibration noise is at the back of car . Stuck parking brake components ......lots possibilities.
Friend recently had noises at rear . Could not locate issues with car on the ground .
Ned to,put it on a lift , where you can see and move around push and pull and see what is going on.
We crawled around on ground ...waste of time .....could not figure chit out ......soon as we got it on a lift where you can actually see what is what took like five minutes to pin point the problem,
To Noises when I punch it
