IIRC it's a 5/8 sqr so yes you are correct.
If you can't find an 8pt socket, one of those multi-size, one-tool-does-it-all sockets with the spring loaded pins in it will work (if you get the larger size one). Also good for some locking wheel nuts that someone has lost the key for. Just need to hide it in the bottom of the toolbox so your buddies don't see it.
M
M
Still can't find a 5/8 8 point . Will a 12 point work
