I just bought my first corvette, a 1979 4-speed. I hear alot of people talking about recurving the distributor (which I understand means changing the springs and weights to advance ignition timing at lower RPM).
However my distributor looks like this:
Correct me if I"m wrong, but I don't think this is the stock distributor. Do I still need to recurve the distributor?
Its a stock dizzy with an aftermarket coil. You need the curve kit for a normal 1979 Chevy HEI dizzy. While in there you should clean and lube things up.
Also check the vacuum advance and read up (search) on how to set everything.
Buy a Curve Kit and a Timing light.. first, disconnect vac adv hose ..then see how much initial adv and mechanical advance you are getting and what RPM it maxs out.. Ideal is total advance [ Initial of 10-12* or more on high output motors, plus mech adv ] to get 34-36* all in by 2500-3000 rpm.. start with stiffest springs and work to lightest ..
I like the Crane adjustable vacuum-advance/distributor recurve kits, which have the springs and vacuum-advance limiter plate, along with the adjustable vacuum-advance, and a good set of directions for optimizing your advance curve. The HEI kit is #99600-1, I believe, and that should be available through most online parts-stores, or even perhaps in-store at some places.
I sent my distributor to a guy in Memphis TN, he makes sure the bushings are okay, shims the shaft to the right amount of clearance, and sets the curve based on the mtr, what heads are used, type of trans, rear end gear, application. When it returns, he tells you what to set the total timing is suppose to come in at w/o vacuum advance and with the the vacuum hooked up. There's no guess work, he has an old distributor machines. PM me if you want the guy's phone #.
Is there an drivability issue that needs to be fixed? Research the topic before you start changing springs. Get a timing light and determine what your present curve actually is and then determine if you need to change anything. You can get some springs and then make changes and see what the results are. If you have a Performance Distributors HEI they can be of a lot of assistance. You may just have their coil but likely you have their distributor too. They generally give you a nice performance curve on their distributors so you may have a pretty good setup now.
You should check to see if that distributor is a Davis D.U.I. or just the cap from one.
If it is, it should have one of their modules in it. This could have been replaced, however.
It should have an aluminum base. may be tach drive or not.
On the outside of the base, near the cap flange area, it should have a number etched in it.
If you call Performance distributors with that number, they can tell you all about that distributor.
Yes, I have a Performance Distributor in my 71. It's a very fine piece. The tach drives are $$ but worth it.
