Light problems
Old Apr 10, 2016 | 05:34 PM
Rw81's Avatar
Rw81
Cruising
Default Light problems
My marker lights and my headlights work fine. I have no break lights or turn signals. I also do not have any dash lights either.
I have checked and I don't have any blown fuses and I replaced my flasher also. Any help would greatly be appropriated. Thanks.
Old Apr 10, 2016 | 05:35 PM
Rw81's Avatar
Rw81
Cruising
Oh, I forgot, I have a 1981 coupe.
Old Apr 10, 2016 | 07:15 PM
The13Bats's Avatar
The13Bats
bad bulb? bad ground?
Do hazards all work?
Brake and turn are the same filiment in the lamp
Old Apr 10, 2016 | 08:21 PM
Rw81's Avatar
Rw81
Cruising
I went and looked and the emergency flashers were on, but do not work. I don't know how they got turned on but when I turned them off all the other lights worked. Turn and brake. I still don't have emergency flashers or dash lights.
Old Apr 11, 2016 | 07:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Rw81
...I still don't have emergency flashers...
Replace the flasher.
...or dash lights...
Check the IP fuse. If the fuse is good, turn the light switch ****.
Old Apr 11, 2016 | 08:14 PM
Rw81's Avatar
Rw81
Cruising
I replaced the flasher in the fuse panel. Made no difference.
I have the dash out now. Could the dash lights have a bad circuit board?
Old Apr 11, 2016 | 08:17 PM
The13Bats's Avatar
The13Bats
there is one flasher for hazards another for turn lamps...2 total
Old Apr 11, 2016 | 08:19 PM
Rw81's Avatar
Rw81
Cruising
Where is the other flasher located
Old Apr 13, 2016 | 07:21 PM
Giant_Robot's Avatar
Giant_Robot
turn signal flasher for me is on the passenger side near the ball vent. (77)
Probably this is the issue, as your lights wont work without it. also, mine didnt stick so well in the plastic connector and would come loose, might want to bend your tabs for a tighter fit there.
(i think in other years they might be in the center of the dash?)
Old Apr 14, 2016 | 09:56 AM
Rw81's Avatar
Rw81
Cruising
Thank you very much. I will check that tonight.
Old Apr 14, 2016 | 10:09 AM
Rw81's Avatar
Rw81
Cruising
Any ideas on how to get my dash lights working?
Old Apr 14, 2016 | 05:22 PM
ETTEVAY's Avatar
ETTEVAY
1st Gear
Does the '68 have two flashers?
To Light problems
