Vin answers???
Old Apr 14, 2016 | 11:24 AM
Curt Corwin's Avatar
Curt Corwin
Default Vin answers???
i BOUGHT THREE PARTS CARS A WHILE BACK FOR MY 1979. i DID A VIN SEARCH ON MY CAR i AM RESTORING AND IT CAME BACK, BUT WHEN i TYPE THE VIN FROM ONE OF THE PARTS CARS THAT I HAVE IT SHOWS THAT IT DOESN'T EXIST. WHY??? I CAN FIND NO INFO OUT ABOUT THE CAR. VIN # 1Z878AS437967. LIKE TO KNOW WHETHER IT WAS A SCRAP CAR OR SALVAGE STOLEN ANYTHING. THE PREVIOUS OWNERS I TALKED TO ALL BOUGHT FOR A PARTS CAR. SEEMS WEIRD. ANY HELP WOULD BE APPRECIATED.
Old Apr 14, 2016 | 11:34 AM
CV62Air's Avatar
CV62Air
My guess is the "A" does not belong. Recheck your vin tag and you can use the vette fact website to help you decipher--- http://www.vettefacts.com/C3/1978.aspx
Good luck.
Old Apr 14, 2016 | 11:53 AM
Curt Corwin
Originally Posted by cv62air
my guess is the "a" does not belong. Recheck your vin tag and you can use the vette fact website to help you decipher--- http://www.vettefacts.com/c3/1978.aspx
good luck.
just checked, the "a" is there and belongs. But thanks nice idea.
Old Apr 14, 2016 | 12:25 PM
ed427vette's Avatar
ed427vette
There is no letter A in a 1979 Corvette vin. There should be a number 9 in the spot where you have the letter A. It does NOT belong there. If one is there, something has been done to it. Do you have a picture of the VIN tag?
1979 Corvette VIN
VIN Range - 1Z8789S400001 to 1Z8789S453807
Character Position Code Significance
1-2 1Z Chevrolet Corvette
3-4 87 Coupe
5 8 Base Engine
5 4 L-82 Engine
6 9 Last Digit of Model year
7 S St Louis Assembly Plant
8-13 6 Digit Build Sequence Number
Old Apr 14, 2016 | 12:48 PM
joewill's Avatar
joewill
your vin search is only as good as the database you are searching. what are you using?
Old Apr 14, 2016 | 02:11 PM
Curt Corwin
1979 Corvette VIN
3-4 87 Coupe
5 8 Base Engine
5 4 L-82 Engine
The VIN tag I am having Problems with is actually from a 1980. Sorry to be confused. My fault. It comes up like it doesn't exist.
Old Apr 14, 2016 | 02:15 PM
Curt Corwin
I have tried 3-4 different ones. on ebay, vin check, quora, instavin, c3 corvette registry has the same beginning numbers but not same last 6 production numbers, as expected.
Old Apr 14, 2016 | 02:20 PM
MelWff's Avatar
MelWff
It clearly states on sites such as Instavin they have no records prior to 1981. Most of these sites use the newer 17 digit VIN's which is why you cannt find anything.
Old Apr 14, 2016 | 02:43 PM
CV62Air's Avatar
CV62Air
Try NY state dmv title search.. came up with this...
Old Apr 14, 2016 | 02:52 PM
Curt Corwin
THANK YOU, I AM A ROOKIE AT THIS.
Old Apr 14, 2016 | 03:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...VIN # 1Z878AS437967...
That's an otherwise correct VIN for a 1980 L-48 Corvette. If you are trying to use Carfax for your search, Carfax does not cover anything older than the 1981 models.
Curt: turn off your CAPS LOCK.
To Vin answers???
