Throw Out Bearing Problems
Old Apr 20, 2016 | 06:01 AM
6839's Avatar
6839
2nd Gear
Default Throw Out Bearing Problems
Greetings:
74 Vette, 350, 400hp, crate engine, new block, new NAPA clutch, 4 speed rebuilt. After a few hundred miles throw out bearing began squawking. I could feel vibration in the clutch pedal. Throw out bearing was replaced. After a hundred miles or so it began squawking again. The clutch was pulled and showed signs of slight scorching. A new heavy duty clutch & throw out bearing along with a brass pilot bearing was installed. I could feel vibration in the clutch pedal but no noise. After 50 miles or so I’m getting squawking again. It started making noise twice while in reverse. The clutch fork was considered a possible source of the problem, but nothing obvious. Help, please
Old Apr 20, 2016 | 08:06 PM
cagotzmann's Avatar
cagotzmann
Originally Posted by 6839
Greetings:
How much clearance in your setup between the bearing and the pressure plate fingers are you running?
It sounds like they are in constant contact and never release
With the clutch pedal released there should be .050 to .150 gap ( hydraulic setup) but I believe a mechanical setup should be similar
Old Apr 20, 2016 | 08:28 PM
Cooter Tech's Avatar
Cooter Tech
Is your clutch pedal returning to the full up position? If the pedal is resting on the linkage the throw out bearing will constantly spin and fail.
Old Apr 21, 2016 | 06:03 AM
6839's Avatar
6839
2nd Gear
To Throw Out Bearing Problems
