Engine Timing
Old Apr 22, 2016 | 05:13 PM
D_Williams's Avatar
D_Williams
Default Engine Timing
Is it possible for the timing mark on my harmonic balancer to be off? And if so how do I fix it?
So...I finally got around to timing my engine (finally have a working timing light) and according to the harmonic balancer my engine is approximately 30 degrees advanced at idle and it sounds like it will die before I get to 0 degrees TDC. I know I am hooked up to the #1 spark plug.
Any ideas?
If it helps, I have a 1970 454
Old Apr 22, 2016 | 05:35 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Yes it is possible, the glue can delaminate and balancer will slip out of position, did you plug vacumm advance?
Old Apr 22, 2016 | 09:16 PM
D_Williams's Avatar
D_Williams
No I didn't plug the vacuum advance, but I will try that tomorrow.
Will the vacuum affect it that much?
Old Apr 22, 2016 | 09:23 PM
Calo69's Avatar
Calo69
Pull and plug the rubber line itself not actual can.
Light will jump all over place if not
Old Apr 23, 2016 | 10:11 AM
Revi's Avatar
Revi
Are you using a standard timing light or a dial back timing light?
If a dial back, are you using it correctly? Depending on how you have it set, you can get some weird timing indications.
And yes, your timing mark on the harmonic balancer can be off. They can and do slip with time. If that happens, it will need rebuilt or replaced.
One way to check your balancer is to remove all of the spark plugs and turn the engine over by hand (a pain, I know), use a mirror and look in the #1 cyl spark plug hole, you'll be able to see the piston reach TDC (make sure you are on the compression stroke). When the piston reaches TDC, the timing mark should align with "0" zero on the timing tab. If not, it has slipped, making all future timing adjustments off.
Old Apr 23, 2016 | 03:48 PM
D_Williams's Avatar
D_Williams
Thanks both for the replies!
I may check that at some point, removing the vacuum advance hose helped a little bit and I was able to set the timing. Is it normal for the idle speed to drop a little (~200 rpm) with the vacuum advance not hooked up?
I am using the dial timing light, but I was keeping it at 0 initially (to find TDC) before I set it advance 4 degrees (by turning the dial on the light to 4deg and setting the balancer mark at 0)
Old Apr 24, 2016 | 09:11 AM
BKbroiler's Avatar
BKbroiler
Disconnecting vac advance retards the timing somewhat and slows the idle speed.
To Engine Timing
