Compass mirror
Old Apr 23, 2016 | 04:06 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Default Compass mirror
I was at the wrecking yard today getting some parts for my daughters car. I found a few cars that had the rear view mirrors with On Star, Home Link and compass. I know I can't wire up On Star to a 1978 Corvette but I was wondering if the Compass was internal in the mirror or is that just a display on the mirror and there is another box somewhere in the car. The ones on the mid 2000 Cadillacs look like they mount with the same windshield button. Anyone know?
Old Apr 23, 2016 | 04:22 PM
Richard454's Avatar
Richard454
It's a simple 4 wire hook-up. Power -ground and two wires to the temp sensor. The compass is in the base of the mount.
Do a search for the Gentex 177. I bought mine off eBay for $30 in excellent condition. Make sure it comes w/ the 7 pin harness. New- sensors are like $25...I have the part# on my home/office computer if you need it.
I put mine on a 71- so I had to to a little modding of the mount to work on the windshield header.
Old Apr 23, 2016 | 04:51 PM
Vette-kid's Avatar
Vette-kid
Pretty cool idea! Is there one that works with a traditional mirror button? Would be pretty easy to get power and ground from the dome light.
Old Apr 23, 2016 | 06:07 PM
mikem350's Avatar
mikem350
Dome lite power is constant 12v
Old Apr 23, 2016 | 07:05 PM
Vette-kid's Avatar
Vette-kid
Valid
Old Apr 23, 2016 | 07:16 PM
The Punisher's Avatar
The Punisher
I installed a Donnelly mirror. Has compass,temp, auto darkening , and map lights. It is a little smaller then the gentex 177
Old Apr 23, 2016 | 09:52 PM
Richard454's Avatar
Richard454
Have you got the dimensions and a model number?
I wasn't aware of the smaller Donnelly- The Gentex are 10½"- and the Vettes 74-82 are 10". 69-73 are 8½" The vettes are windshield mount from late 76.
My solution for the smaller years is to use the 74-76 sunvisors.
When I researched the mirrors- Gentex and Magna/Donnelly both are GM suppliers. and have the same harness/ wiring
Here's the wiring for the 7 pin-
GM wire harness color function
PIN 1 PINK POWER +12 volts
PIN 2 BK CHASSIS, GND
PIN 3 LT GRN BACKUP LIGHTS
PIN 4 GY TO AUTO DIM OUTSIDE MIRROR
PIN 5 PINK TO AUTO DIM OUTSIDE MIRROR
PIN 6 DR GRN/WT TEMP PROBE
PIN 7 BK/WT TEMP PROBE
Note: Pin 3 is to be connected to the backup lights to turn off the auto dim feature in reverse. If you intend not to use this feature connect the LT GRN wire to chassis ground. If this pin is floating the auto dim will not work properly.
Old Apr 23, 2016 | 10:40 PM
The Punisher
I don't have a part number. But here is a picture of it. It measures 9-15/16" across and 3-1/2" wide.
Old Apr 24, 2016 | 12:12 AM
RockyL32's Avatar
RockyL32
Thanx for all the responses! I'll hit up the wrecking yard again on Monday see if I can find one without the OnStar buttons.
Old Apr 24, 2016 | 07:42 AM
corvette74's Avatar
corvette74
Look for a 03 to 06 sierra. I just got mine this week. It has compass and temp. The temp sensor is in the middle of the grill near the bottom.
Old Apr 24, 2016 | 09:23 AM
502 C-3's Avatar
502 C-3
I put one from a gm pickup in my 74. I removed the factory mirror bracket and glued on the piece for the new mirror on the windshield. Compass is built in the mirror. Easy mod and works great.
Old Apr 24, 2016 | 10:56 AM
Bloodzone's Avatar
Bloodzone
I really like this upgrade idea. I wonder if you could place the temp sensor somewhere under the hood to monitor engine compartment temps? They may get too high for the sensor to handle.
To Compass mirror
