Transmission problem
Old Apr 26, 2016 | 05:42 PM
jgonzo's Avatar
jgonzo
Default Transmission problem
My 1982 coupe seems to hang (about 2-4 seconds at high rpm 3500) before shifting 1-2. It just happened all of a sudden. Can I make an adjustment or is this the beginning of a larger problem? Any help would be appreciated.
Old Apr 26, 2016 | 06:17 PM
diehrd's Avatar
diehrd
Open hood, motor off , using your fore finger pull the TV cable out several times and let it snap back in place , road test report back
Old Apr 26, 2016 | 09:14 PM
jgonzo's Avatar
jgonzo
Where can I locate this?
Old Apr 27, 2016 | 12:02 AM
diehrd's Avatar
diehrd
You will need to remove the air cleaner and look at the throttle linkage there will be a cable that goes down to the transmission , that is the TV cable ..
To Transmission problem
